Old 08-18-2009, 04:20 AM   #1
mts
Stupid dyno question - Torque signal
Where's the best/easiest place to pick up a torque signal when putting the car on a dyno?
2004 550 SE #1081 of 1953 (sold)
1997 911 Targa (sold)
mts is offline   Reply With Quote
Old 08-18-2009, 05:39 AM   #2
Porscheectomy
Most dynos are a set of weighted rollers. The car is set on the rollers and accelerates as hard as possible. The time it takes to get to each speed point tells you what the horsepower of the car is. Torque is calculated from the horsepower data.
There's no "torque signal" to be had from the car.
Old 08-18-2009, 05:54 AM   #3
Are you thinking about an ignition signal?
2003 Boxster
Roosell is offline   Reply With Quote
Old 08-18-2009, 06:43 AM   #4
mts
Yes, the local one reads that to do the math.
Old 08-18-2009, 10:09 AM   #5
Engine Surgeon
You need to place the dyno's inductive pick up on the wires that feed one of the coil packs... Then set the dyno's settings to pick up the signal every 720 crank degrees.
This will give you both TQ and HP Vs engine RPM.. This is the settings that I use on my dynojet with the M96 engine.
Old 08-21-2009, 09:40 AM   #6
Brad Roberts's Avatar
Then.. try not to run over/suck up the cable
B
