Old 08-18-2009, 11:09 AM   #5
Jake Raby
Engine Surgeon
You need to place the dyno's inductive pick up on the wires that feed one of the coil packs... Then set the dyno's settings to pick up the signal every 720 crank degrees.
This will give you both TQ and HP Vs engine RPM.. This is the settings that I use on my dynojet with the M96 engine.
