Old 08-10-2009, 04:32 PM   #1
GTA_G20's Avatar
Auto to Manual conversion *Flame suit on*
Yes I know I'm about to get ripped. But I have been given a boxster 2.5 for next to nothing with a blown motor but it is an auto'tragic'. Since I need to do a 2.5 swap already, how much more intensive would it be to get rid of the slushbox and put in a normal 3pedal set up.
GTA_G20 is offline   Reply With Quote
Old 08-10-2009, 04:57 PM   #2
Lil bastard's Avatar
Spendy - New DME (ECU), New Master Cylinder, clutch master cylinder, New Wiring Harness, New Sway Bars (rear), Springs, Cooling system mods, New Pedal Box arrangement, New Instrument Cluster, New Center console(?), New Steering Wheel, probably more that doesn't come to mind.
Of course, that's in addition to the new Box, clutch, slave, shifter, trim plates.
It'd likely cost more than the car's worth. It'd be cheaper to skip the freeby and just go out and buy yourself a 2.5L 5-speed.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 08-10-2009, 05:37 PM   #3
GTA_G20's Avatar
such a shame
Old 08-10-2009, 06:15 PM   #4
On the other hand, don't rule out the Tiptronic S without at least driving one first.
1976 BMW 2002
1990 BMW 325is
Old 08-10-2009, 06:19 PM   #5
tonycarreon's Avatar
"auto'tragic'"? "slushbox"? "normal 3 pedal set up"? what on earth would make you think you'd get ripped?
Old 08-11-2009, 05:28 AM   #6
find a totaled 09, fab in the PDK, take pictures then let me know if it kicks ass.
Old 08-11-2009, 10:51 AM   #7
GTA_G20's Avatar
Haha, I was thinking about doing this and putting a vtec motor in my 09 BoxS and dropping the big boy in my '97 base. Then I'd have 2 sleepers!!!! Sick, wicked and nasty
Old 08-11-2009, 11:04 AM   #8
PDK wouldn't mount on the M96, completely different motor/DME unless someone tells me I'm wrong.
Old 08-11-2009, 04:19 PM   #9
been gathering all the information on a tip to 6speed swap for quite some time, but this idea is very! interesting... the new engines still run off 7.8 motoronic so if you are on that, you may be able to... hmmmm
Lexington, KY Go CATS!
http://i187.photobucket.com/albums/x...s/DSCN0406.jpg
2001 986S... 3.6 swap (yep 7.2->7.8), PSS9's, GT3 seats, OEM 986 Carrera 5-spokes, and much more http://i187.photobucket.com/albums/x...me/burnout.gif
1987 928 S4 white on red and... dead
2004 Chevy Surburban... drinks gas like its cheap or something
easyc is offline   Reply With Quote
Old 08-11-2009, 04:36 PM   #10
GTA_G20's Avatar
I love a clutch and rowing the gears, I was raised driving standard and anything else is just not normal to me. Well I did enjoy driving an E46 M3 SMG but thats a different breed than whats mated to my box's engine
Old 08-11-2009, 04:43 PM   #11
http://sharkwerks.com/porsche/technical-articles/64-2009-997s-sharkwerks-project-car-software-tuning.html
"To start things off you can see that in order to be able to communicate, read, edit and upload the data on the SIEMENS SDI3 requires a lot of precise and rather nifty gear. The Bosch Motronic ECUs of old were far more cooperative that's for sure. As of now there are no tools available specific to this new ECU. EVO had to engineer and manufacture their own to "open the communication door" into this ECU. Also, this ECU does not use the same shape bosch type map structure. It uses the same map structure as the SDI4 ECU found in the Cayenne TTFSI which we have learned about a year ago through trial and error. This made us VERY familiar with the maps in the SDI3 found in the 997. Once the ECU has been what's known as "boot-strapped" (this is tricky indeed) we gain access to stock data and "read" it out as shown here."
http://www.6speedonline.com/forums/boxster-cayman/176628-evomsit-software-2009-dfi-caymans-available.html
"Hey fellas, just a quick note to let you know that the EVOMSit software (which we ran so successfully on our 06 Cayman S etc...) is now available for the DFI 2009 based Caymans using the new SDI3 ECU."
Old 08-12-2009, 07:26 AM   #12
Can it be done? Yes. Will it be laborious? Yes. Will it be expensive? Very. Will you ever get your money out of it? No………………….
JFP in PA is offline   Reply With Quote
Old 08-12-2009, 07:45 AM   #13
Brucelee's Avatar
As suggested, if you are going to pull the entire drivetrain, find a 3.6 or 3.8 based drivetrain to make it worth your while.
Rich Belloff
Old 08-12-2009, 07:47 AM   #14
GTA_G20's Avatar
There is coolant mixed with the oil but the car runs so... I dont mind the slush box but would prefer manual. If its not cost effective I wont waste my time
Old 08-12-2009, 12:49 PM   #15
I know you said it's blown, but it might be worth replacing the oil/water heat exchanger, as that could be the place the mixing is taking place on a car that old.
'01 Boxster S, 51k miles
yimmy149 is offline   Reply With Quote
Old 08-12-2009, 03:24 PM   #16
GTA_G20's Avatar
I could definately do that. I havent taken possession if it yet but very shortly it'll be here. I thought motor was toast and was told not to run it for long in that condition and engine should be replaced
Old 08-12-2009, 10:47 PM   #17
Topless's Avatar
Or simply some blown internal freeze plugs. A guy in Texas recently repaired a motor (oil/coolant mix) with this simple failure. The car is in the great white north after all.
Old 08-13-2009, 06:21 AM   #18
GTA_G20's Avatar
Ok new thread to follow
