Old 06-19-2009, 09:44 PM   #1
anyone intalled NHP full exhaust???
Has anyone done this install???
Will be installing the following NHP full exhaust. slightly different from pics. I will be running: Headers with Sport Cats, ByPass Mid pipes, and the Muffler.
I am considering GIAC chip tuned for this setup?? anybody? agree, disagree?
thanks
2003 Boxster S
2K3_Boxster_S is offline   Reply With Quote
Old 06-19-2009, 10:38 PM   #2
Topless's Avatar
I have not but others here have done similar installs. If it were my car I would get a custom reflash with a dyno or a rolling tune and shoot for a big fat torque curve rather than peak hp. We buy hp but we win races with torque. More effective than off the shelf "chip" reflashes.
Some pitfalls others have faced with aftermarket header/cat/exhaust so just a friendly heads up:
Serious droning resonance at 3k rpm
Continuous CEL issues.
Cannot pass state smog inspections (not street legal)
Headers made contact with nearby PS lines, car caught fire and burned to the ground (yes, several Boxsters have gone car-b-que after installing headers)
Pay attention to the details.
Old 06-20-2009, 05:23 AM   #3
Yes you must tie back the power steering lines or else you will have issues. I lucked out and it happened in a driveway when someone who had a hose happened to be standing right there when the fire started. No damage other than a messy engine from the fluid and a burst PS hose.
Chris
87 944S brought back to life
Dragonwind is offline   Reply With Quote
Old 06-20-2009, 06:16 AM   #4
He's not going to have CEL since there's 4 cats shown in the pic. As long as the O2 sensors are plugged in then it'll be fine.
Old 06-20-2009, 08:03 AM   #5
yes I will be running the front and rear O2's, although the front CAT's will be 200 cell cats (much less restrictive) than a factory 600 to 800 cell CAT. and that can but rarely cause a CEL.
not to worried about the CEL even if it does it will be fixed when the car is tuned.
2003 Boxster S
Old 06-20-2009, 08:06 AM   #6
Chris
Very much thanks for that information, I will definetely make sure the PS hoses are out the the way . That would not be good. Also was this on 3.2 or 2.5 or are the hoses identical on a both???????
2003 Boxster S
Old 06-20-2009, 08:12 AM   #7
Thumbs up
Thanks I will see If I can get that torque curve up. It definetely feels like it needs more torque especially at lower rpms.
Also, it is a street legal setup where I live. there are no smog inspections and I am still run CATS.
Thanks everyone for the help.
2003 Boxster S
Old 06-20-2009, 04:31 PM   #8
Lil bastard's Avatar
Personally, I wouldn't sink any money into an exhaust until we get more info from Jake Raby.
Jake has intimated that only a couple of the aftermarket setups actually outperform the OEM gear and that most actually underperform OEM.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 06-20-2009, 08:53 PM   #9
I understand what you are saying. after market support for the boxster's is fairly new. NHP is providing dyno sheets with each part. And the OEM exhaust seems very restrictive 1 1/2 inch exhaust inlets?????? I just can't imagine how going to a equal length merge header and from 42mm to 50mm overall piping, removing 4 restrictive CATS is not going to out perform OEM. I can't believe that's possible.
wish I could do a pre and post dyno on this install but I'm afraid I will only be able to do a post dyno. Let you know in a few weeks when I return home. Also the muffler is straight through no baffles.
2003 Boxster S
Old 06-21-2009, 07:45 PM   #10
Engine Surgeon
I continue to gather data... But it's not looking like I'll end up sharing the info publicly.
I'd most certainly end up in court if I did so, the results are that bad in some instances.
Old 06-21-2009, 09:24 PM   #11
so in other word spending any money of aftermarket exhaust is not worth it ?
udontknowjack is offline   Reply With Quote
Old 06-21-2009, 11:02 PM   #12
I have the full system on my 2.9L. Looks nice, sounds good. Made a difference on my 2.9 over a stock system, but my engine is far from stock. My biggest complaint is that the tube diameter is wrong for using the factory U pieces that you have to use in the install, so it's pretty much impossible to not have exhaust leaks.
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
cnavarro is offline   Reply With Quote
Old 06-21-2009, 11:31 PM   #13
so you have NHP Full exhaust installed on your 2.9L and you are saying that it does not bolt up perfectly? If so then, my whole set will be getting returned.
Also specify exact set-up if you have NHP.
example: Headers with sport cats, mid pipes with or without cats, and exhaust.
2003 Boxster S
Old 06-21-2009, 11:56 PM   #14
Court??? what?? ever heard of the 1st? if you want to claim upgrading headers and exhaust is worthless and can't post data that you have then your opinions and claims are worthless.
If you have installed NHP headers and dyno'd a 3.2L then post the results:
EX: Maxspeed Dyno Sheet suggest's 8hp 4LBS change
Exhaust and headers on any other car would yeild gains in HP and or torque, just curious why it would be the opposite for a Boxster?
2003 Boxster S
Old 06-22-2009, 12:43 AM   #15
Well you could avoid any litigation possibility by merely reporting those systems with positive gains.
You certainly could not be sued by a company for not mentionining them at all or for not saying anything negative about their products.
1976 BMW 2002
1990 BMW 325is
Old 06-22-2009, 06:44 AM   #16
Engine Surgeon
You'd have to be in my position to understand the flack that gets started when a discovery is made and shared.. Gathering the data scientifically without variables being imposed is hard enough, dealing with the people after it happens is unbearable.
Lets just say if you like to sound like you are going faster than you really are, then you'll love most of the after market systems.
Old 06-22-2009, 06:50 AM   #17
I think everyone is missing an important point: Jake and Charles are owners of two businesses that specialize in providing upgrades and replacement components for Porsches. As such, they could potentially be held to a different standard in a lawsuit as “the market” considers them “subject matter experts.” Therefore, their “opinions” carry a lot more weight than that of an average enthusiast that publishes their like or dislike for a particular component, regardless of how the data was collected. As a business owner myself; I can fully appreciate their reluctance to state their knowledge on some subjects as the facts as they understand them can still end up costing a whole lot of cash to defend when you piss someone off…………….
Old 06-22-2009, 06:52 AM   #18
Don't you just love all the marketing hype on the street.....................
Old 06-22-2009, 07:11 AM   #19
Don't worry I completely understand now, didn't realize your are a salesman.
scared of losing business to competitors.
2003 Boxster S
Old 06-22-2009, 08:09 AM   #20
Way to go...............why not insult one of the most respected independent Porsche engine builders in the country.......................Jeez
