Old 04-23-2018, 08:03 AM   #1
fitted new soft top, not closing properly
Hi ladies and gentlemen. I've just finished fitting anew glass window top from AutoTopsDirect.com Wow, what a massive PIA that was. I have the 101 projects book and watched the how too on Roaring Tigers Garage on YOuTube. Very unimpressed with the 101 book instructions, the YouTube vid was far better.
Once I finished the top wont close correctly. This was something I was concerned about as I was never happy with the routing of the cables that goes around the rear edge of the side windows at either end. Are there images of how they rout? I thought I snapped a couple of pics of the cable but didn't.
At the lower end it fastens through an eyelet and there is a guide that seems to push it outboard, is this correct?
At the front/top end it connects to the spring aluminium plate that goes in the front corners then goes back. At the back edge of that plate there is a cut in the plate right in the corner where it is folded. Is it supposed to go through there?
Note on the last pic of the drivers side the cable is outside the guide piece, I can tuck it behind that, but it doesn't help.
TIA
Thanks for any help or suggestions.
Budget 1999 986. Not much, but it's mine all mine.
Volvo C30 picked up Euro delivary 6/26/08 drove the Nurburgring 6/30/08
Adrian Thompson is offline   Reply With Quote
Old 04-23-2018, 08:41 AM   #2
911monty's Avatar
Maybe this will help?
Old 04-23-2018, 09:14 AM   #3
Thanks. I replaced those plastic panels with new ones when I did it. See the screw attaching the cable to the bottom? When installed does the cable go straight up, or does it angle towards the outside of the car around the outside of a tab? That's how I have it, which I thought was the correct way, but now I'm thinking it should go straight up.
Old 04-23-2018, 09:23 AM   #4
911monty's Avatar
It routs exactly as shown, straight up. You can see the guide/support on the new piece I am holding just above the tab, Also see that spring/lever on the main bow? did you get that routed properly?
Old 04-23-2018, 09:34 AM   #5
I may not have. I'll dig in tonight. thx.
Any advice on the other end?
Old 04-23-2018, 09:37 AM   #6
911monty's Avatar
Check out Mike Focke's thread on the soft top. He may have some photos of that end. Gotta run or I'll miss my tee time. Good Luck
Old 04-23-2018, 10:15 AM   #7
Great, thanks. It did help with one issue. I do appear to have the lower cable attached correctly.
This is the pic on his site.
It's not easy to see, but the cable is attached just as I have it. it doesn't got straight up, but angles out at the bottom. I've put a green line on his, which is what I have and a red line on what i thought may have been the correct routing, but apparently isn't.
Now I know I need to concentrate my efforts on the other end that attaches to the aluminium plate. That's a pity as I'm not sure how much I'll have to undo and re-do including goop and double sided tape.
I'll count this as some progress!
Old 04-24-2018, 07:01 AM   #8
OK, some progress.
Last night having proved to myself that the lower cable attachment was correct I turned my attention to the upper portion above the door glass. As you can see from the images I posted yesterday the seal at the rear edge of the door glass was bulging out. After removing the side seal (the part that's integral with the front seal) then the side metal extrusions with the smaller seal it looked like the cable was running correctly on the sides as well. So I tried to close the top again. I could get it almost there but the catch wouldn't quite engage in the header rail. By using one hand to pull the top/frame forwards and down, I could then just-just engage and close the hood. It's now closed but very very hard to do. For now I'm letting it sit a couple of days before I try to put the seals and metal extrusion back on in the hope that the fabric and cable will give a little.
The front edge of the hood seems to sit low against the header rail over the windshield. I'll try and post some images later, but right now my phone is throwing a fit and not downloading the pics I took.
Old 04-24-2018, 07:33 AM   #9
OK, I've got a couple of pics off my phone.
Here you can see it closed. Not perfectly aligned yet. YOu can also see the side seal hanging down not attached.
And here's the top closed. It's hard to see but the front edge of the top is sitting low compared to the header rail. I'm not sue if this because the side doesn't line up, or just that it's super tight and needs to relax/stretch the material a bit?
Old 04-24-2018, 07:46 AM   #10
A couple more. This better shows the fit across the top of the header rail where it seems to sit 'low'
And one more of the side. Do you think this is correct?
