Old 10-10-2015, 07:16 PM   #361
Couple laps in my stock (minus studs and gas pedal) from High Plains Raceway today. Still need to gain some confidence in the car and more in the driver Can't wait to be done with my build... you guys are having too much fun without me.
ianacole is offline   Reply With Quote
Old 10-12-2015, 08:08 AM   #362
Originally Posted by Eric523 View Post
I was the car that came second in qualifying and I wasn't put on the dyno. It was supposed to be random selection. I had rented a car for the race and I think the rental has about 191-193 in it. Give the competitive field of drivers and the full second that the lead car pulled on us, I was interested in the dyno results.
After seeing the results. I was also the one that protested car #1, simply because no legal spec car has ever posted over 200. I also had to write a check for $3500...
At first, car #1 was going to comply with the inspection and insisted the car was stock and I'd lose my $$. The next day... decided to go home instead.
Last weekend a lil birdie told me car #1 has since purchased a new engine. Decided not to go through with the inspection so we didn't find out what was making the additional power on the dyno.
Anyway...I don't have a lot of patience for that kind of stuff. I've been DQ'd before for removing my immobilizer but that was another issue and not performance enhancing at all (never over 186 on the dyno)
Nice job Eric and Tom! I'm glad we have you guys looking out for us.
JEDD is offline   Reply With Quote
Old 10-12-2015, 08:23 AM   #363
Topless's Avatar
Lots of variables between motors, Dynos, weather etc. that said, 203rwhp smells like fish. Car in question may have had a very valid reason for refusing inspection. #2.7L??
Careful Scrutiny of the podium cars is wise in Spec racing.
Old 10-12-2015, 08:46 AM   #364
Time for new brakes!
The pads/rotors are usually done twice a year (spring and fall) and I flush the fluid once per year (fall).
Great stuff Tom! I'm continuing on my build and your videos are always good inspiration.
How about wheel bearings. Do you have a routine for changing those out? From what I've read, it sounds like yearly replacement independent of what condition they may be in.
P993C2S is offline   Reply With Quote
Old 10-12-2015, 09:03 AM   #365
seningen's Avatar
OK, let's talk horsepower.
At the AutoClub Speedway race, the POC had a dyno to measure power output at the rear wheels (there is currently no maximum power spec). The top 3 qualifiers and top 3 race finishers were required to have their cars tested. I had mine tested of my own desire.
Here are three data points;
My Car: 196hp
Car 2: 187hp
Car 3: 203hp
From my perspective, its good news that my $1,800 salvage yard, never been opened, previous tiptronic, engine with 90,000 prior miles still managed 196hp at the rear wheels!
Of course, you might be wondering: with a rating of 200hp at the crank, how can I get 194hp at the rear wheels from a stock engine?
200hp at the crank
- 20hp 10% driveline loss
+ 7hp TopSpeed cat back exhaust (verified on dyno: http://986forum.com/forums/397380-post129.html)
+ 5hp Removal of cat's (verified on dyno)
+ 5hp Under drive pulley (per other testing)
________
196 hp net at the rear wheels
Nice plug for the junk yard :-)
What is allowed in an engine rebuild? Can you custom make the rings?
What limits are there on the valve job.
IMS retrofit isn't going to get you anything.
Anything else would seem to be illegal.
What weight oil do you guys run?
Could you alter the cam to exhaust timing on the vario-cam by displacing a tooth and still not have interference but gain anything?
Note I don't race spec boxster -- but I've been involved in a few M96 rebuilds and its not hard to accidentally alter the vari-cam timing during install (but I've always caught it :-).
Mike
mike@lonestarrpm.com
Old 10-13-2015, 03:18 PM   #366
Boxster Abuser
Eric523's Avatar
Mike
Yeah, some of the high mile motors run good after being loosened up!
There aren't very clear/good/complete rules when it comes to the rebuilds like you would find in Spec Miata or a class run by a more professional organization, unfortunately. So the term "stock spec" really covers most of your questions. At the least, we're trying to make sure everyone is using stock components.
We're supposed to be using stock Porsche pistons and rings. No aftermarket pistons/rings built to same size or anything like that. I have not seen limitations on valve jobs, other than the valves need to be stock.
Oil weight is up to the competitor/engine builder, there is no stock spec. I use 0w-50 Mobil 1 Racing oil.
You cannot legally alter the cam timing. However, I'm sure there are some that do. It is not something I've done or experimented with so I can't speak to the specific advantages.
4.0L Dry Sump Boxster GT race car - HRG #23
2005 Cayenne S - DD
Eric523 is offline   Reply With Quote
Old 10-13-2015, 03:24 PM   #367
Boxster Abuser
Eric523's Avatar
It was questionable to some competitors as to why someone would rebuild a motor that didn't have any apparent issues. Once new motor was in, car set the track record and pole at the next two attended events. There was a competitive field full of multiple race winners all within a few tenths of each other and then one car a full second ahead. Then it popped high on the dyno, 5% higher than the rest. Then declined inspection and went home instead. Maybe he was frustrated and felt unfairly criticized, but some will draw their own conclusions.
2005 Cayenne S - DD
Old 10-16-2015, 07:49 AM   #368
Boxster Abuser
Eric523's Avatar
It has come to my attention that my statement above has been cherry picked to support ones own personal thoughts and I just want to clarify...
A gentleman asked specifically about valve job rules and I replied above, that there are no specific rules in the rule book other than ''stock'', unfortunately. Some that wish to read into that assume that meant I would manipulate a valve job... that's not the case, just you hearing what you want to hear. It was a reply to a question specifically about valve job specifications.
As referenced just beforehand, a rule set like spec Miata actually has several pages about engine internal specifics, like posted below.
I did not say ''I have not seen limitations'' because I have exploited them, I said that because there are no posted values of limitations...
Short of buying new cylinder heads for every rebuild, there are modifications that need to be completed on any regular standard engine build. This is supposed to be cost controlled spec racing and engine rebuilding is part of it. There should be rules with values about plunge cutting and valve jobs and decking heads like any other reasonable spec but BSR is not at that level of precision, yet.
People will believe what they want... even with several independent dyno runs at several tracks back to back against other cars right out of qualifying. We know what the cars are running HP wise across the field because they have ramped up dyno testing and that is a big step forward.
Old 10-16-2015, 09:34 AM   #369
seningen's Avatar
Eric,
Never thought otherwise -- basically having a beer discussion over the net :-)
I'm building a pair of SP-1s, so arguably my question is mute to me. However I do track a Boxster S and I have either rebuilt or been a part of about a dozen rebuilds of these engines and I was trying to envision how the HPs could vary.
Note I'm a EE and shade tree mechanic hack not a professional engine builder -- so this is more of a thought exercise for me.
Mike
Old 10-16-2015, 09:37 AM   #370
seningen's Avatar
I was reading up on the VarioCam -- as I understand it, the solenoid opens up from about 3K-5K, and is shut off above and below. If it wasn't working "properly", you would have different engine behavior. I'm not sure if that would be better or worse overall. I have to think there would be a tradeoff if it was to be engaged all the time as an example.
Mike
Old 10-16-2015, 10:58 AM   #371
Boxster Abuser
Eric523's Avatar
Eric,
Mike
Thanks, I wasn't referring to you at all. It's a good question and anyone that has built an engine would know that cylinder head servicing is part of it. You can't rebuild a head to exact stock originally delivered specs and still successfully service it. Replacing cylinder heads with new every time adds another $8k to an engine rebuild and a terrible idea for cost controlled spec racing. Porsche dealership service departments and factory re manufactured engine program all service heads in similar ways within certain tolerances. Even if you ordered a rebuilt crate 2.5L engine from Porsche, the cylinder head has been serviced. Order up a rebuilt cylinder head from Porsche and that has also been serviced. Unfortunately, those tolerances are not really public info or written in our rule books so there is no guidance as to what acceptable "stock" range actually is. So when I said, "I have not seen limitations", that's what I meant. Not "there are none so it's wide open for porting and polishing and ceramic coatings and flow bench testing." As you can see, some spec classes do have a handle on such things, and Boxster Spec is not one of them.
2005 Cayenne S - DD
Old 10-16-2015, 11:02 AM   #372
Boxster Abuser
Eric523's Avatar
Mike
Better to be working as designed, for sure. These solenoids and tensioners fail from time to time and there is an overall performance loss.
2005 Cayenne S - DD
Old 10-16-2015, 11:10 AM   #373
With all of the engine discussion(!!), I wanted to reply to this by saying that I replace the wheel bearings very two years. Some do it more often, some less and some only when they start to fail. There doesn't seem to be a full consensus that I am aware but most people racing multiple years do get into some type of routine.
Old 11-15-2015, 03:52 PM   #374
Let me start this post by saying that taking your car to the track can be a humbling experience. It is still one area where personal performance is easily measured and easily compared with others. And sometimes, whether you like it or not, the truth just stares back and gives you the middle finger.
Yesterday was one of those days for me.
Well, let's talk about the positive things first; the San Diego region PCA hosted an excellent event at Buttonwillow raceway with both racing and time trials on a beautiful 70F sunny day in middle of Central California farmland.
I also had to opportunity to meet fellow Forum member JayG and his son who were there for the time trial and I got a personal and upclose look at Topless' shiny white Cayman. That Cayman is a beautiful car!
Now, the reality check: I was S-L-O-W. As in 12 seconds off the pace in the first practice session. 12 seconds!!
I got better during the second practice session and took off 5 seconds. Then took another 5 seconds off in the third/qualifying session.
So I was only a few seconds behind the leaders pace right? Unfortunately, no. By the time that I caught up those 10 seconds, the leaders had taken 3 more seconds off of their times. And it wasn't just one or two drivers, 9 of the 13 cars in the Spec Boxster field were 3-5 seconds per lap faster than me!
During the race, I started well and kept up with the race pace (which is almost always slower than qualifying) until the halfway point when I started to fade rearwards. I think that I finished 12th or 13th. I say 12th or 13th because if I actually look it up, then I would know for sure and would have to say that I finished last. Ouch. That hurt.
To sum it up; I sucked and got my assed kicked.
The video should be pretty good since there was a lot of close racing in the first half of the race. I'll edit it quickly and get it posted.
P.S. I did not race today due to the rain that rolled in this morning.
Old 11-15-2015, 09:34 PM   #375
Topless's Avatar
Good to see you out there Tom, sorry it wasn't a better day for you. We all have a few bad days at the track but the good ones keep sucking us back in. Racing ALWAYS beats sitting at home watching Oprah reruns.
Dan and I managed to have a pretty good weekend. We both posted personal best times as the track seemed to get faster all weekend. The Cayman works better at BW than Chuckie because there are more long straights so she can stretch her legs a bit. Still way too softly sprung so I have some work to do over this end of season break. Looking forward to 2016 with fresh tires, suspension, and weight loss.
Old 11-16-2015, 03:35 AM   #376
RedTele58's Avatar
Sometimes you're the windshield, sometimes you're the bug. It was your day to be the bug. Sorry to hear you had a less than stellar day.
Go get the next one.
Old 11-16-2015, 07:49 AM   #377
JayG's Avatar
Great meeting you finally as well. Sorry you had a bad day. I enjoyed watching all you guys with the running start. Real racing!
It was my first time at Buttonwillow. Its a challenging and fast with the long straights. Got into the low triple digits in 4th. Especially fun is the 4th to 2nd downshift at Star Mazda and then fast into the esses Sunset and the front straight. woohoo!
The rain came in the beginning of my 2nd session on Sunday. Got a good lap in and then started a bit of sliding in the corners as the rain started coming down faster. Brought it in, there is always another day...
All in all a great fun weekend.
Old 11-20-2015, 10:28 AM   #378
THStone, you running an external oil cooler or Accusump?
Old 11-21-2015, 09:42 AM   #379
Currently, I am not using either of those. I do plan to install the TechnoSump (2 qt deep sump with horizontal tray) over Thanksgiving.
Old 11-22-2015, 10:35 AM   #380
Thanks. If you don't mind, let me know how it goes. I've been evaluating the engine cooling options out there and have not been able to find a definitive answer ... probably user dependent
  • I've heard the S cooler only provides marginal cooling improvements
  • With an accusump type setup, I've heard that an oil leak will result in the entire system purging itself
  • External setups can be complicated and expensive, and cooler location can expose it to damage
Wish there was just an easy, straight-forward, proven solution
