07-17-2022, 12:12 PM
986 clutch pedal stuck
If anyone could help out that’d be great,
Problem : clutch pedal is stuck down and only comes up if I pull it up, car is able to turn on, able shift gears while it’s on, when on it cannot shift gears when clutch is in.
Possible causes:
(I know I messed up) basically launched the car on a steep hill and smelt like burnt clutch the whole way home, after this happened was the first time my clutch pedal got stuck
Weve replaced the slave and master cylinders but to no avail (had some issues bleeding the system so will be doing that again to make sure that isn’t the problem)
The pedal very slightly moves up now after initial bleed
If anyone has an idea of what’s the problem/solution please help
07-17-2022, 04:09 PM
Simplest things first.
Make sure the clutch pedal return spring is not broken.
07-17-2022, 07:15 PM
Well let's see
Pedal was stuck to floor
bleed system
pedal moves slightly now
Sounds like you didn't bleed it completely or correctly.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
07-20-2022, 07:50 AM
I don't know if its possible, but if the clutch assist spring breaks, possibly could get stuck in a position that won't allow the clutch to move? At the very least it would be something easy to check.
07-20-2022, 08:38 AM
I had a similar symptom when my clutch line between the MC and slave cracked and was leaking fluid. Mine broke inside the drivers side fender and was dripping fluid below the car.
98 Arena Red 986
07-20-2022, 05:18 PM
the clutch assist spring makes it easier to push. If it breaks, it won't stop the pedal from moving
07-20-2022, 07:26 PM
Did you bleed clutch with pedal pushed all the way in?
07-21-2022, 05:36 AM
I know, but I have also heard of them kind of exploding when they snap and in theory could get stuck in a precarious position that would lock it in place. Again, just theorizing from some incidents I've read about
07-21-2022, 07:35 AM
A broken clutch assist spring can definitely stick the pedal on the floor. It happened to me and there are other documented occurrences here (along with replacement tips, how they work and specs for different rate replacement springs). They don’t work the way it would first appear.
Rgds, Fred
07-21-2022, 04:38 PM
If you think it is a broken assist spring, simply disconnect it and see if that is the problem
