Old 06-22-2021, 06:58 AM   #1
Turn key instant off
Is there wiring to turn off ignition instantly when turning key to off position? without pulling out the key.
I am searching this but cannot find..
Thank you!
stjimmy is offline   Reply With Quote
Old 06-22-2021, 07:32 AM   #2
Rob175's Avatar
Not sure why your engine doesn't stop when you turn the key to "OFF".....BUT IF YOU MEAN the radio stays on until you pull the key out of the slot.........then.........all is normal and that's how the system works. There's an electrical part in the switch mechanism that will shut off the radio when the key is removed from the slot.
Your system is working as designed. (If the radio doesn't shut off after the key is pulled out...THEN....you have an issue)
Old 06-22-2021, 08:12 AM   #3
If you are meaning the car doesn't shut off when you turn the key to the off position, then you have a bad ignition switch....which is VERY common. If this is the case, replace it.
What Rob is referring to is accessory retention, which is designed in almost every modern car.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 06-22-2021, 08:39 AM   #4
Sorry for misunderstanding. System is normal working!
I am looking for to turning off radio without pulling the key out of the slot.
Old 06-22-2021, 08:41 AM   #5
My system is normal, sorry for misunderstanding again!
I really want my radio off without pulling the key
Old 06-22-2021, 08:42 AM   #6
Only way to do that is to turn the radio itself off, or open the door. Opening the door will cancel the accessory retention.
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 06-22-2021, 08:43 AM   #7
Oh, and it will turn itself off after a few minutes if you dont open the door after turning the car off. So your choices are:
turn radio off
Open door
Wait
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 06-22-2021, 09:12 AM   #8
PLP
PLP's Avatar
Or never turn it on to begin with...
PLP is offline   Reply With Quote
Old 06-22-2021, 09:12 AM   #9
turn radio off
Open door
Wait
Thank you!! I tested without opening the door before
This will solve my situation. I just want to keep my key in cylinder.
Thanks again!
Old 06-22-2021, 09:18 AM   #10
This will help to save some gas
Old 06-22-2021, 09:27 AM   #11
He meant the radio
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 06-22-2021, 09:34 AM   #12
Thanks again!
Leaving the key in the ignition will cause the car's electronics to stay on and run the battery down fairly quickly. Take the key out.
