Old 06-03-2021, 11:26 AM   #17
When installing one type of metal into a dissimilar metal. like mild steel into Aluminum.
Your going to get Galvanic corrosion. It is caused by an electrical process. The dissimilar metals actually create an electrical charge. Even if you use stainless steel.
So because the Engine block is Aluminum I use Anti-seize on things like spark-plugs, or exhausts studs- or bolts if I have to replace them.
If I have to replace an exhaust stud or bolt I use mild steel with Anti-seize. That way if I ever have to go back in and I break a stud off it is easy to drill out.
The practice of using mild steel exhaust studs with brass or copper nuts has been used in the Automotive industry for over 100 years.
They did it that way so that the nut would not seize to the stud from the affects of repeated heat and cold cycles.
The reason you see bolts now being used to hold the exhaust manifold on is because it is cheaper.
Profit is the driver. A bolt is one piece and one step. As opposed to two pieces and manufacturing processes. And two steps to install.
Use what suits your needs or what you feel is best for the situation.
Some may say I am over thinking it, I am just using what has worked for over 100 years for that specific application.
Well said! I believe you are dead on with it being a cost factor. On some factory vehicles they do use mild steel and copper nuts and I believe its as you stated its easier to drill out if it ever breaks.
What type of anti seize do you use? I was using regular but was told to start using nickel on spark plugs. Was going to use copper for the exhaust
Johnny5 is offline   Reply With Quote
