Old 06-07-2020, 05:24 PM   #1
Um, this weird scratch on the climate control
Hello hive mind.
I recently bought back an old 1999 Boxster I used to own. Unfortunately, it came with a lot of fresh defects. I have had all the big mechanical things taken care of, now I'm down to cosmetics.
The climate control display has this orange line across it that...well, I guess the best way to describe it is simply to provide a photo.
Is there a way to fix this -- take it apart and repaint it, or buy a replacement screen -- without having to replace it with a whole new unit?
Thanks!
986Chick is offline   Reply With Quote
Old 06-07-2020, 05:36 PM   #2
The LCD's in that section have died. If you are handy the unit can be disassembled and repaired . Or buy a known good used unit and replace .
rfuerst911sc is online now   Reply With Quote
Old 06-07-2020, 05:40 PM   #3
JBauer's Avatar
Buy a kit and fix it. Easy repair.
Old 06-07-2020, 05:45 PM   #4
Motorist & Coffee Drinker
78F350's Avatar
Here's an old thread: http://986forum.com/forums/boxster-general-discussions/56132-ac-led-screen.html
Here's links to parts:
https://900designs-container.zoeysite.com/986-and-996-climate-control-lcd-screen-replacement-kit
https://modulemaster.com/rebuilds/shop/comfort/lcd-repair-kits/porsche-lcd-kit/
Old 06-07-2020, 05:48 PM   #5
piper6909's Avatar
Could your issue be something like this?
http://986forum.com/forums/boxster-general-discussions/77694-help-my-cluster-has-worms.html
If so, and you're lucky, your solution may be as easy as post #13. If you can live with it for a while, do nothing for a few months and see what happens.
2010 Subaru Forester
Old 06-07-2020, 05:56 PM   #6
Thank you, that was very helpful.
Of the two links you supplied, is there any difference between the end result for each? Do they look OEM?
Old 06-07-2020, 07:42 PM   #7
jcp
Pelican sells a LCD repair kit. Put one in my '99. Very easy do and not expensive.
jcp is offline   Reply With Quote
Old 06-08-2020, 08:15 AM   #8
Will there be cake?
tonythetiger's Avatar
the repair kit is easy...its actually fun. I swapped mine out with a parts car, but later repaired the bad one with a kit. the icons on my kit were a little different, so be aware if you think that will bother you, Some might think its an improvement. I like the stock icons because they aren't intuitive, so im the only one that understands them. :+)
Old 06-08-2020, 11:14 PM   #9
Mine hasn’t done that, but a couple of my indicators have died, works fine (except for the foam blowout every now and then) so I’m in need of a new one too. Looks pretty straight forward. Have new coil overs to install this summer... not looking forward to it...
