Old 03-08-2020, 05:01 PM   #1
Mysterious electrical device.
I was changing the evap valve on my Boxster's fuel filler pipe today and found some sort of electrical sensor hanging in there. It's rod-shaped, about 1 1/2" long and 3/16" in diameter, with an 8" lead on it that has a connector on the other end. If someone can tell me what it is and where it is supposed to go I would really appreciate it.
GTRider9 is offline   Reply With Quote
Old 03-08-2020, 05:19 PM   #2
piper6909's Avatar
Year would help.
Pics?
Old 03-08-2020, 06:44 PM   #3
1997 Tip, 2018 Macan
rexcramer's Avatar
If your car is '97-'04, you need to have this PDF factory parts catalog. The expanded drawings should help you identify your part/number. They also have the newer catalogs if needed.
https://drive.google.com/file/d/1gUVtQYvav64U4tp_d9kATIHx0QWRfUAw/view
Please introduce yourself and post a pic of your car. Most of us are friendly and will be glad to help. Although some will bite when provoked. Safe travels.
Old 03-09-2020, 06:42 AM   #4
JayG's Avatar
and it ain't real without pics
Old 03-09-2020, 07:40 AM   #5
Who's askin'?
maytag's Avatar
Haha... that's awesome.
You're not talking about the Fuel Door Lock, are you? "Rod Shaped" and in that vicinity made me think about this.....
Old 03-09-2020, 03:27 PM   #6
I have been there, it is a sensor, if you look close it should be captured by the assembly that held the evap valve, it should be held laying on the fill tube.
Luckyman01 is offline   Reply With Quote
Old 03-10-2020, 09:16 PM   #7
Thanks for all the responses! Special thanks to rexcramer for the parts pdf--I've been really frustrated by all the errors and omissions in the dealer parts diagrams. When I get some time (this weekend?) I'll introduce myself and my 2000 Boxster more formally.
Old 03-14-2020, 06:49 AM   #8
JayG's Avatar
I was think that as well
Old 05-10-2020, 12:14 AM   #9
It's probably the OSVR reed contact which sits inside the bleeder valve just under your fuel filler. The bleeder valve has an orange circular face on it. There's a good article in pelican parts that shows you where it goes but there is an obvious recess inside the valve. Without it fitted, you may have a problem filling up. This is an issue that I've had for a while as my car doesn't have one nor can I find the wiring for it!!!
Sent from my ASUS_Z01KD using Tapatalk
dak138 is offline   Reply With Quote
Old 05-10-2020, 12:16 AM   #10
In fact if you can take a picture of the connector on the other end in place and where it leads to I'd be eternally grateful...
