08-22-2019, 01:27 PM
#21
Originally Posted by A8ked
Have you checked the headlight relay ?
There is no relay for the headlights (except DRL cars).
Originally Posted by piper6909
You're not supposed to get a ground there, you're supposed to get 12v.
With fuse removed and headlight switch on, you should get 12V+ on one side of the fuse socket and ground on the other side (indicates a circuit is completed through the switch, bulb and connectors).
08-22-2019, 01:28 PM
#22
Test each headlight for continuity between the low beam positive and negative pins (with headlight out of car, bulb in and after verifying there are no shorts/missing insulation on wiring inside headlight).
Check the cars headlight socket side connector for power (with key and headlight switch on).
08-22-2019, 01:41 PM
#23
Ground on the other side if the bulbs are connected. If the bulbs aren't connected and still get ground on one side then there's a short somewhere. But I don't think that's the case in this instance because the problem is no power to the fuses.
I'd check the Hi/Low beam switch. According to my diagram it feeds power to the fuses. (Although my diagram is from a 99, but most likely it's the same). Check for power at the yellow/white wire at the switch. That's the wire running down to the fuses.
08-22-2019, 01:44 PM
#24
Yes, it is the same.
If OP’s tests confirm continuity at the headlight, but no power at the fuse or headlight connector, the high/low switch is suspect.
08-25-2019, 05:52 PM
#25
Yeah, not getting 12v either.
08-25-2019, 05:56 PM
#26
Buying the $250 Low/High Beam Stalk switch next. That replacement will be a little more of an operation than the Headlight Switch. I’ll keep everyone posted.
08-25-2019, 06:09 PM
#27
I'm sure you can find a good used one. We're not 100% that it's the switch, even though I suspect it. I'd hate for you to drop $250 on little more than a hunch.
Post in here:
Boxster and Cayman Parts for Sale or Wanted - 986 Forum - for Porsche Boxster & Cayman Owners
There's a lot of people on here selling parts at good prices.
09-02-2019, 07:09 AM
#28
Thanks. I looked there and a used one that’s 17 years old is $180. I might as well get the new one for $250. I’ll get it, install and keep you all posted.
By the way. Appreciate everyone’s help.
Update: I have to wait till the dimmer switch is back in stock. Not springing for the genuine part at $407
09-12-2019, 06:37 PM
#29
All,
So I now have the part and immediately hosed myself. Went in to remove the airbag with a T30 torx with a bit and extension. The bit came loose and is stuck in there now, and not in a way where I can loosen the screw. Tried to get it out for an hour. No joy. I am sucking wind right now.
Ed
Reason: Added info
09-13-2019, 09:30 AM
#30
Does anyone think this could be the ignition switch? I know I had a similar problem in my car. No low beams but all other lights were good. Took the switch out takes about 10 mins and it was visibly broken. I do know the switch was redesigned at some point to mitigate this failure but is a common problem on the early cars.
09-13-2019, 02:47 PM
#31
1998 Boxster Silver/Red
All,
Ed
Faced the same challenge when I replaced my 4-spoke. I think I used some black tar/gum compound to ensure the bit didn't get stuck.
I hope you can get it out. Good luck.
1998 Porsche Boxster
09-13-2019, 03:01 PM
#32
For future reference, use a wrench, not bits.
09-14-2019, 09:47 AM
#33
Or a plastic baggie or some tape to secure it to the driver...
Yeah, well hindsight 20/20 so not of much help now... sorry.
However, in order to retrieve the bit maybe use some 3M double sided automotive adhesive tape on the driver or some gorilla tape and of course a magnetic driver helps.
Good luck
"Cool Prius!" - Nobody
09-18-2019, 01:58 PM
#34
Ignition switch
Check the ignition switch. I had a similar issue about a week ago. I restarted the car and the headlights worked.
A few days later, no headlights, no climate fan (display was on), and no wipers. I went to restart the car but when I put my hand on the key the wipers, fan, and lights turned on.
It turns out the ignition switch is wearing out and I have to turn the key backwards a few degrees after starting to move it from start to run position for the headlights, wipers, etc. to work.
09-27-2019, 10:38 AM
#35
I installed the Dimmer Stalk switch. Didn’t fix the problem.
Ignition switch next?
09-27-2019, 09:44 PM
#36
Ignition switch should have been first
09-29-2019, 09:23 AM
#37
I don’t have all of the ignition switch symptoms. It’s only the headlights. Everything else works.
09-29-2019, 10:11 AM
#38
Yes, but it’s a quick and cheap thing to check.
09-29-2019, 01:34 PM
#39
Unfortunately, we led him down the hi/low switch path. It seemed like a prime suspect according to the wiring diagram.
For my part, I apologize.
09-30-2019, 11:30 AM
#40
Had a similar issue on a '98, on one side only. I found out that when the headlight assembly was locked back into the tray, the connector assembly on the tray was giving (getting pushed back) and not seating all the connections to the headlamp assembly. I can't remember for sure how I got access to the back of the assembly but when I applied pressure to the tray with my hand while the assembly was being installed, I was able to get a good connection and solve the problem.
I think I went in by removing the wheel well liner but truly don't remember for certain.
