Old 08-22-2019, 01:41 PM   #23
piper6909
piper6909's Avatar
There is no relay for the headlights (except DRL cars).
With fuse removed and headlight switch on, you should get 12V+ on one side of the fuse socket and ground on the other side (indicates a circuit is completed through the switch, bulb and connectors).
Ground on the other side if the bulbs are connected. If the bulbs aren't connected and still get ground on one side then there's a short somewhere. But I don't think that's the case in this instance because the problem is no power to the fuses.
I'd check the Hi/Low beam switch. According to my diagram it feeds power to the fuses. (Although my diagram is from a 99, but most likely it's the same). Check for power at the yellow/white wire at the switch. That's the wire running down to the fuses.
piper6909 is online now   Reply With Quote
