Old 05-21-2019, 08:59 AM   #12
Will there be cake?
tonythetiger's Avatar
Originally Posted by elgyqc View Post
My intention is to pull the ignition barrel, so the oil is to lubricate the bolt which is below the barrel. The reason I am thinking oil and not graphite is that it is about 8 inches from where the barrel sits to the end of the bolt, all down hill, so my thinking is that the oil will get all the way to the bolt. Not sure that graphite powder would be able to work its way down.
But that being said perhaps I should try the graphite first. Is there a liquid that could be used to deliver the graphite and that would evaporate after? Some kind of alcohol?
for that I would use white lithium grease and work the bolt back and forth a little. That should last forever. Comes in tubes and spray. The spray is a mess but you can spray on cardboard and transfer with brush, toothpick etc.
