Old 05-18-2019, 02:12 PM   #1
Ignition switch electrical
I’m guessing that the electrical part of my ignition switch is failing. 1998 boxster with what I’m guessing is the original switch. With the switch in the run position but the car not running, I have full function of both the headlights and wipers. Once the car is started and running, the wipers do not work and the headlights are very dim. I am able to get full function of both if I start and shut-off the car multiple times.
To me this sounds like the ignition switch. What does everyone think?
Sammyj is offline   Reply With Quote
Old 05-18-2019, 02:42 PM   #2
Definitely, 100% bad ignition switch.
Old 05-18-2019, 02:43 PM   #3
Will there be cake?
tonythetiger's Avatar
not sure, but the switch is easy enough to replace, takes about 5 minutes once you squezze yourself under the dash. You need a small flat blade screwdriver to loosen set screw (DONT REMOVE IT) and it pops right in. Pedros Garage explains the entire procedure in detail.
search on amazon for 4A0 905 849B, the vw/audi switch to see significant savings...its the same part selling for 30-60 dollars under porsche badge.
Old 05-18-2019, 04:33 PM   #4
Thank you guys for the quick replies
Old 05-18-2019, 06:16 PM   #5
piper6909's Avatar
While we're on the subject of ignition switches, which is better; The genuine Audi or the OEM?
Pelican has genuine Audi for $38.50 and OEM brand for $29.75
The OEM brand looks like the genuine Porsche, but I'm unclear if it's the OEM supplier or just OEM is just a brand name?
Which would you all recommend? Mine's pretty stiff to turn, so I think it's due for a new one before it bites the dust completely.
Old 05-18-2019, 06:50 PM   #6
Need For Speed
KRAM36's Avatar
Just get the Meyle Ignition Switch, they are excellent and not expensive. I got mine from ECS Tuning shipped First Class Mail for $12.32 total, but they have raised the price $1 since I bought mine.
2003 Boxster S
Old 05-18-2019, 08:05 PM   #7
elgyqc's Avatar
... Mine's pretty stiff to turn, so I think it's due for a new one before it bites the dust completely.
An ignition that is stiff to turn may not be the electrical switch. An easy test is to remove the electrical switch and see if that eliminates the stiffness. That was not the case for my 2000 5-speed. Turning the key was difficult, then about a week ago it would not turn even to the first position... removed the electrical switch... same problem. I finally had to remove the whole steering lock mechanism and found that the bolt (bolt as in a dead-bolt) that slides into the steering shaft to lock it was stuck in the advanced position. Once the mechanism was out I oiled the bolt and everything now works. Meanwhile I had bought a used mechanism that I installed. My other Boxster is showing the same stiffness so I am going to remove the ignition key barrel and spray oil in that I hope will make its way down to the bolt and loosen it up.
I plan to do a thread on this experience for future generations because learned a lot.
Grant
Old 05-18-2019, 08:39 PM   #8
Will there be cake?
Am I the only one that thinks oil in the ignition switch is a bad idea? I have always lubricated locks and such with graphite. Graphite lubricant doesn't attract dust and dirt, which will damage the locking mechanism. Also, i would be curious what oil does to the plastic parts of this mechanism over time.
Old 05-18-2019, 09:00 PM   #9
Definitely don't put oil or other wet lubricants in lock mechanisms. It will attract dirt/debris and eventually gum up pretty good.
Graphite only.
Old 05-19-2019, 05:48 AM   #10
Need For Speed
KRAM36's Avatar
Yep, graphite only, although this has nothing to do with the op's question.
Unless you just recently replaced the ignition switch, you're a complete idiot not to spend $15 to get a new ignition switch and replace the old switch if you're pulling the old ignition switch out to see if that's what's causing the hard turning of the key. If you can't cough up that $15, sell the car now.
2003 Boxster S
Old 05-19-2019, 06:26 AM   #11
Tailwind's Avatar
http://986forum.com/forums/boxster-general-discussions/75214-possible-ignition-switch-issue.html#post594616
I bought the Meyle from Amazon $28.00 based on members' recommendations.
'99 986 Base
2010 Golf TDI
'74 914 2.0
'56 356A
Tailwind is offline   Reply With Quote
Old 05-19-2019, 06:59 AM   #12
elgyqc's Avatar
My intention is to pull the ignition barrel, so the oil is to lubricate the bolt which is below the barrel. The reason I am thinking oil and not graphite is that it is about 8 inches from where the barrel sits to the end of the bolt, all down hill, so my thinking is that the oil will get all the way to the bolt. Not sure that graphite powder would be able to work its way down.
But that being said perhaps I should try the graphite first. Is there a liquid that could be used to deliver the graphite and that would evaporate after? Some kind of alcohol?
Grant
Old 05-19-2019, 08:04 AM   #13
Need For Speed
KRAM36's Avatar
Meyle ignition switch $14.94 including shipping. First link in this search.
https://duckduckgo.com/?q=https%3A%2F%2Fwww.ecstuning.com%2Fb-meyle-parts%2Fignition-switch%2F4a0905849b~mey%2F&t=ffsb&ia=web
Or $20.49 from Pelican including shipping.
https://www.pelicanparts.com/cgi-bin/ksearch/pel_search_2016.cgi?command=DWsearch&make=POR&description=4A0-905-849-BMY-INT
2003 Boxster S
Old 05-21-2019, 08:59 AM   #14
Will there be cake?
for that I would use white lithium grease and work the bolt back and forth a little. That should last forever. Comes in tubes and spray. The spray is a mess but you can spray on cardboard and transfer with brush, toothpick etc.
Old 06-15-2019, 09:49 AM   #15
I will be very happy to pay you $250 to replace this damn switch.. I can't believe how you guys are doing this, and yes I've seen how you are doing it. What a PITA.
mikeinmass is offline   Reply With Quote
Old 06-15-2019, 10:16 AM   #16
Will there be cake?
The PITA is half the fun.
