Old 03-29-2019, 10:24 AM   #1
Window regulator question
Hello all
I am a little familiar with these window regulators and the mechanism that drops/raises the window an inch or so when open and closing the door. I have a slight issue with this mechanism that I wish someone can help me identify.
The mechanism works only when the door handle is pulled.
So if I am out of the car and pull the door handle to open the door, the window will drop. I open the door and I don't notice anything weird. But then I realize the window has come back up because I try to close the door and the window hits the roof. I realize that the window drops if I have the door handle pulled but as soon as I let it go, it raises back up.
Is this the switch in the handle and does it mean the switch is just misaligned?
Any help will be appreciated. Thanks
xuno_gil is offline   Reply With Quote
Old 03-29-2019, 10:43 AM   #2
The lock mechanism will usually be the culprit. The part will run around $200.00+. Had to replace mine in my 2001. Name:  986doorlock.jpeg
Sent from my SM-N960U using Tapatalk
mmassey0125 is offline   Reply With Quote
Old 03-29-2019, 12:59 PM   #3
78F350's Avatar
With the door open, if the window does the short drop and rise when you lift and release the handle, the problem is most likely the micro-switch in the door latch. The best way to repair it is to replace the whole latch.
You can use a much less expensive latch from a similar VW/Audi, but it may need a slight modification to work.
Check out this thread:
http://986forum.com/forums/boxster-general-discussions/70183-vw-do-latch-actuator.html
Old 03-30-2019, 08:17 AM   #4
Thanks a lot!
This was very helpful. It completely makes sense that the issue is the door latch and the link to that other thread is going to make this a very easy and inexpensive fix.
Great help.
