Old 01-22-2019, 11:45 PM   #1
Caliper Rebuild - 3 pistons stuck
Hey everyone,
I'm in in the process of doing a caliper rebuild, but I'm having a hard time with 3 of the brake pistons. I took out the dust boots, and then used the compressed air / wood method. One of the pistons shot right out, 1 budged a bit, an the other 2 did not move at all. Is there something I'm doing wrong, or do I have frozen pistons? I'm blowing the air through the hole where the caliper would connect to the brake line - is this correct? Or should I be blowing through the bleeder nipple? Any other suggestions? I have tried prying / pulling on them since I do not want to damage them.
Thanks!
'02 Boxster S
'16 FR-S
'01 M5 (sold)
'07 Mazdaspeed3 (gone)
speedyspaghetti is offline   Reply With Quote
Old 01-22-2019, 11:47 PM   #2
"shot right out"
Does that mean that one of the pistons is all the way out and now you can't pressurise the space behind the others?
2001 Boxster S, TipTronic in Seal Grey aka "The Imp"
2001 TE50, ESS in (now) Grigio Titanio Matallizzato aka "The Golden child"
TrumpyAl is offline   Reply With Quote
Old 01-23-2019, 06:08 AM   #3
just use 2 screwdrivers to pry them out. should be a non issue
Old 01-23-2019, 07:28 AM   #4
Originally Posted by TrumpyAl View Post
"shot right out"
It pushed most of the way out and then I pulled it out by hand - should I have kept it in so that I can get full pressure on the others?
'02 Boxster S
'16 FR-S
'01 M5 (sold)
Old 01-23-2019, 07:31 AM   #5
Yeah, pop it back in and use the block of wood to keep it from being pushed out again.
Try to use air pressure to move all of them partially out, and then lever them with screwdrivers to get them the rest of the way out.
Old 01-23-2019, 07:33 AM   #6
Marring that recessed ring, while I'll try to avoid it, won't damage the function, correct?
'02 Boxster S
'16 FR-S
'01 M5 (sold)
Old 01-23-2019, 07:47 AM   #7
Yeah that makes a lot of sense... I feel stupid now. Oh well. Thanks!
'02 Boxster S
'16 FR-S
'01 M5 (sold)
Old 01-23-2019, 07:54 AM   #8
they are actually tougher than you might think, but nah, a few scratches there won't affect anything as its just the dust boot retainer.
You can wrap the screwdriver with a paper towel if you're worried
Old 01-23-2019, 10:01 AM   #9
Gotcha - thanks! Hopefully this rebuild and new rotors / pads will solve my vibration once and for all.
'02 Boxster S
'16 FR-S
'01 M5 (sold)
Old 01-26-2019, 06:43 AM   #10
Do pay attention to the bed-in procedure.
And next time around, don't switch pad compounds without also replacing (or machining) the rotors.
