Old 05-28-2018, 05:53 PM   #1
oil in the coolant and vise versa.. :(
Had an oil change done three weeks ago. Dumbasses put in too much oil. The first time I put the pedal down and brought the revs up. Poof white smoke. I assumed the Air oil Separator must have some how self destructed so ordered a new one. While I waited I continued to drive the car but like an old geezer. A few days later my coolant light came on and the car got hot. Put in some coolant and tried to diagnose.
Here is what I found.
Oil in the coolant reservoir...chocolate milk and a lot of it.
Drained the oil...chocolate milk as well and this oil was only a couple of weeks old.
Is it possible that having too much oil ...say half a liter to a liter extra could have somehow damaged the AOS and the oil cooler at the same time?
Or is it more likely that the AOS was slowly starting to go but the extra oil caused it to rear its ugly head and the extra oil pressure blew the oil cooler?
I'm hopeful that this will be an easy fix.
I'm terrified the extra oil pressure may have somehow blown a head gasket.
2001 boxster S still runs and idles fine..only has issues if |I try to bring the revs up under load...reving in the driveway for example does not produce any smoke.
Eastcoastmod is offline   Reply With Quote
Old 05-28-2018, 06:06 PM   #2
Several things come to mind.
They put oil in the coolant tank.
The oil cooler is a known failure point.
The AOS has no connection to the coolant system.
My bet is the oil cooler. Could it have been just coolant added to oil because of a coincidental failure?
How do you know they put too much oil in?
What do the plugs look like? All 6 the same?
Old 05-28-2018, 06:15 PM   #3
After driving and getting the large poof of white smoke I parked the car to do some research. That's where I read about the AOS and decided to order one.
The next morning I checked the oil level like I always do after a change just to be sure it was at the correct level. It was reading too full. All the lines were lit up. I also did the test of running the car while trying to pull of the oil cap. I didn't have any suction when doing this but still ordered a new AOS.
Oh and I changed the plugs...all the ends looked great but...there was plenty of oil in the sleeves around the coils
While nothing is impossible, I doubt my guy put coolant in the oil or the other way around.
Old 05-28-2018, 06:30 PM   #4
here are a couple of pics of the oilhere is the dreaded sludge
This oil is only a few hundred kms old.
I tried to make a shadow so you could see it better.
Old 05-28-2018, 08:37 PM   #5
1997 Tip, 2018 Macan
rexcramer's Avatar
IMHO, I seriously suggest that you don't run it anymore until you find out WTF is going on. You may make a minor problem something considerably worse.
Old 05-28-2018, 09:34 PM   #6
Not likely that your car suffered two simultaneous independent failures. Also, extra oil shouldn't damage the oil cooler.
Or is it more likely that the AOS was slowly starting to go ...
Yes, this is possible.
...and the extra oil pressure blew the oil cooler?
No. Extra oil shouldn't damage the oil cooler. The oil pump creates the oil pressure which is (generally) independent of the total volume of oil in the engine.
Is it possible that having too much oil ...say half a liter to a liter extra could have somehow damaged the AOS..
Yes, this is possible. But only the AOS would be affected and since the AOS is not connected to the coolant system, there is no way that an AOS failure can result in coolant in the oil.
If the oil cooler is the only failure, then yes, it will be fairly simple. If not the oil cooler, then you likely have a very serious problem.
No, extra oil would not affect oil pressure. But you still might have a blown head gasket for other reasons.
Never operate an engine with oil/coolant intermix until you know the cause.
I'd do a coolant system pressure test. This might help point you in the direction of the coolant leak.
If not, then I'd remove and pressure test the oil cooler.
If the oil cooler is ok, then I'd do a compression and leak down test on all cylinders.
Once you've got this far, you should have found something that points you in the right direction to find the problem.
Old 05-28-2018, 10:20 PM   #7
The Radium King's Avatar
perhaps related you your ticking noise ...
http://986forum.com/forums/boxster-general-discussions/69557-ims-something-else.html
Old 05-30-2018, 07:01 AM   #8
Will there be cake?
tonythetiger's Avatar
I suggest you read flat6innovations write up ( google intermix 986 boxster) and click into article. compare your symptoms including what happened up until seeing the intermix issue.
I doubt it is the AOS or the oil cooler, or a blown head gasket. Boosters don't blow head gaskets very often.
I don't know the mileage but hope it isn't the dreaded cracked head. Oil reads high and coolant disappears. Does the temp light flas slowly now?
Let us know.
Old 05-30-2018, 05:50 PM   #9
Sorry was away for a bit.
Parked the car.
Yes coolant going somewhere but no visible leaks.
Yes oil reads high...even after I flushed it myself and only added 7 litres of oil.
Read very low at first which it should. A coulple of drives later and it now reads high.
Can't notice any symptoms on the dip stick.
Coolant was vanishing at an alarming rate though.
Will do a bit more research before I send it to my guy for a barrage of testing.
Thanks to everyone who is responding. I fear the end may be near for the motor.
As for the ticking I posted a long time ago, a clip on the from bumper had come loose. Slowing from highway speeds it would start banging in the wind. fixed the clip and the issue went away.
Old 05-30-2018, 10:03 PM   #10
My most recent engine failure went like this...
Losing coolant.
Continued to drive the car.
Replaced coolant tank. Still losing coolant.
Tightened all coolant connections. Still losing coolant.
Coolant system pressure test fail. Still losing coolant.
Compression/leakdown test. Leakdown test fail.
Engine stumbles once and low oil pressure light on intermittently.
Engine back to running fine. Continued to drive car. Low oil pressure light on solid.
Continued to drive car. Engine stopped running. Won't start or run.
Installed replacement engine.
I hope that your situation works out better than mine did.
Old 06-25-2018, 09:56 AM   #11
The new oil cooler should be here tomorrow. While I have everything apart, is there anything else I should be looking at or cleaning?
Old 06-25-2018, 10:51 AM   #12
1998 Boxster Silver/Red
Be sure to install new o-rings.
1998 Porsche Boxster
Old 06-25-2018, 06:19 PM   #13
BIGJake111's Avatar
I had similar symptoms. Car is currently parked until I have a chance to check if it’s the oil cooler but I’m just accepting that’s it’s by and large a cracked head and it’s time to start saving for a 3.4 liter swap...
I swear we didn’t see intermix issues here a few years ago and now there is a thread every other month.......
Old 06-25-2018, 10:10 PM   #14
The age and mileage of the 986 "fleet" continues to increase each year. Thus, a lot of engines are reaching the end of their useful life.
This is normal, expected and it will get worse as the fleet continues to age and add mileage.
Old 06-26-2018, 06:57 AM   #15
I am predicting it's not the oil cooler.
I would have the poor thing towed to a shop and have the coolant system pressure tested. My gut feeling is that you have a cracked head, when the engine gets hot, the pressurized coolant is being pushed into the oil galleys and ends up in the crankcase. Which is why your coolant goes down and your motor oil goes up.
It doesn't look like you have that much oil in your coolant tank, when the coolant cools it's probably sucking a little oil into the cooling system.
2001 Boxster
2007 Toyota Highlander
Old 06-27-2018, 06:55 AM   #16
Thanks for the info guys. Cooler got delayed but I'm starting the teardown today anyway. Hopefully it shows up today so I can finish the job and get back on the road. I am praying that it's not the head.
Old 06-27-2018, 09:13 AM   #17
Thoughts? pic of the oil cooler removed.
Oil cooler or head?
It appears that sludge is only on the coolant side in the pic.
Old 06-27-2018, 09:15 AM   #18
Thoughts on the pic
Name:  oil cooler removed.jpg
Size:  366.9 KB Thoughts on the pic of the oil cooler removed
Old 06-27-2018, 09:52 AM   #19
911monty's Avatar
Pressure test the cooler.
Old 06-27-2018, 11:04 AM   #20
No surprise you have chocolate milk in the oil cooler which contains the same oil that's in the pan.
I'm betting your motor has an internal issue causing the intermix.
I would have it hauled to a real mechanic who can determine the exact issue. Your local POC members should be able to provide you leads to a competent wrench unless you're comfortable dropping and rebuilding yourself.
brianmch is offline   Reply With Quote
