Old 05-18-2018, 06:43 AM   #1
steved0x's Avatar
If not using the bumpsteer feature, any benefit to running motorsports front toe arms
I've got a set of these sitting on my shelf:
RSS Adjustable Front Toe/Bump Steer Kit PORSCHE - RSS
I am wondering, if I'm not using the bump steer feature (since I am not lowered), what would be the benefit of installing these vs the OEM style front toe arms?
https://web2.carparts-cat.com/default.aspx?32=11523&51=14400478459&55=416+020+0000&35=144&125=0&36=914&124=914&1146=914&14=4&34=q12,100601,100603&1105=1&10=9CB24619B36B40C49B8F5C20C1091E3D348004&12=140
They both have a ball joint at the outboard end right? So no rubber, just a monoball?
I'm wondering if I should install these arms and if I would receive any benefit?
Old 05-18-2018, 07:19 PM   #2
Racer Boy
Racer Boy's Avatar
You probably wouldn't notice any difference.
Old 05-19-2018, 05:33 AM   #3
jsceash's Avatar
The benefit is not just bump-steer. They are more rigid to take the abuse of tracking, If you ride rumble strips and the like while your on track these are a good upgrade.
Old 05-19-2018, 08:57 AM   #4
steved0x's Avatar
I might put them on next time I go to tweak the alignment up front.
