Old 01-03-2018, 11:10 AM   #1
Gear knob removal
I have a '99 Boxster with 5-speed manual. I want to change the gear knob, but I can't locate any Allen set screw as mentioned in my Bentley service manual. I also can't simply pull it off as Pelican Parts mentions. Any suggestions??
TomKimbrough is offline   Reply With Quote
Old 01-04-2018, 09:08 PM   #2
Gear knob removal
In some cases, you have to twist the bottom portion of the knob counter clockwise to release it. In others, it's clockwise. Aftermarket generally has set screws.
2001 Boxster S, Metallic Black, 6 Speed Manual, 3.2 liter engine.
RobertKing is offline   Reply With Quote
Old 01-04-2018, 11:24 PM   #3
Hmm, not sure what twists on any stock shifter? Never seen a lock ring or otherwise? It should pull straight off. It takes more effort that you think.
Old 01-04-2018, 11:47 PM   #4
Gear knob removal
If it can be removed simply by force, I'd rather drive a chevy.
Old 01-04-2018, 11:54 PM   #5
They are just pressed on... aftermarkets require a set screw of some sort but stock are press fit. Even my GT3 shift knob presses on. Very secure. No issues.
Old 01-05-2018, 04:57 AM   #6
The shifter knob is removed by pulling straight up. Make sure you don't smack yourself in the face once it comes loose. Some replacement boots have a screw holding them on
Woody
Old 01-05-2018, 05:22 AM   #7
RedTele58's Avatar
This.
Ask me how I know.
Old 01-05-2018, 10:53 AM   #8
Yes, it takes way more force to pull it off than you would ever expect. And yes, you're likely to smack yourself in the face when it comes loose!
Old 01-05-2018, 11:27 AM   #9
If possible lower the top , that way you can straddle the shifter and pull up with force . Doing it this way you won't smack your face but you do put Mr. Johnson in harms way ! Be safe out there .
Old 01-05-2018, 11:49 AM   #10
I think some oem knobs use a set screw. That will likely be right where the top of the boot is on the front or the back.
Old 01-05-2018, 02:48 PM   #11
I used a slide hammer. It makes it very easy.
__________________________
'58 356A coupe, just a driver
356Guy is offline   Reply With Quote
Old 01-06-2018, 11:21 PM   #12
How did you go about that? How did you mount the slide hammer?
Old 01-07-2018, 03:43 AM   #13
Gear knob removal
In most cases, the original can be removed by twisting the lower portion of the knob counter clockwise. If there is no set screw, this is how they were originally locked in place.
Old 01-07-2018, 07:29 AM   #14
It came with some thread on adapters. I used the L shaped adapter underneath the knob. One quick little pop and off it came.
Old 01-07-2018, 09:59 AM   #15
I did the same when pulling the Wood Nardi steering wheel off on my X1/9 when I was 20 years old.....hit me right across the bridge of the nose and knocked my silly for a few seconds!
I remember sitting in the drivers seat with the wheel in my hands thinking "What the h_ll just happened!??"
Old 01-07-2018, 11:29 AM   #16
No. They pull straight up and off, as everyone else has already pointed out.
I guess you'll be hitting the Chevy dealerships tomorrow.
Old 01-07-2018, 11:48 AM   #17
LOL, I did the same thing trying to remove the pulley off a bug generator when I was that age. I hit myself right between the eyes. Now I have a small scar to remind me not to do that anymore. The benefit of getting older is it looks like a wrinkle now
Woody
Old 01-07-2018, 11:56 AM   #18
Hey Woody, Can you tell us why you go by It'sNotANova? Wonder if there's a good story there...
MikeMcMo is offline   Reply With Quote
Old 01-08-2018, 12:07 AM   #19
Ah! Very nice! Beats a knob in the chops!
Old 01-08-2018, 12:11 AM   #20
Dude, why did you post this info a second time? It just not correct...
