Old 06-10-2017, 12:12 PM   #1
Thoughts on Water Pumps
My 2000 with 109,000 miles still has the original water pump, hoses and overflow reservoir. I have a leak somewhere near the water pump and given the age of everything I am not that concerned whether it's the pump, a hose or the overflow; I am going to replace it all. Does anyone have experience with the Gates water pump 134-09063238 from Partsgeek? It's $77.98 which makes me leary.
Thanks,
2000 base tip, desnorkeled, secondary cat delete, underdrive pulley.
jrblackman is offline   Reply With Quote
Old 06-10-2017, 12:29 PM   #2
Feedback welcome
As I read more I have already decided against the one I mentioned previously but additional feedback is welcome.
Old 06-10-2017, 12:34 PM   #3
1997 Tip, 2018 Macan
rexcramer's Avatar
Here are a couple of links that may help you decide. Have you decided what anti-freeze you are going to use?
http://986forum.com/forums/general-discussions/61051-pierburg-water-pump.html
2000 Porsche Boxster Base Convertible - Water Pump, Thermostat & Hoses - Page 1
Old 06-10-2017, 12:38 PM   #4
There Is No Substitute.
rick3000's Avatar
Buy a Pierburg WP, they are same ones that come in the Porsche box for a bit less. It's not worth (in my opinion) trying to save money on anything to do with the coolant system in these cars.
Old 06-10-2017, 03:41 PM   #5
steved0x's Avatar
I ordered a gates from amazon as experiment, I didn't like the look of it when it came, had a metal.impellor (description said composite). I sent I back and got a pierburg, much nicer, felt smoother.
Old 06-10-2017, 04:07 PM   #6
Chuck W.'s Avatar
Also, while your in there, it is a good time to change the belt and motor mount if you haven't yet.
1995 Porsche C4 Cab
Old 06-10-2017, 07:52 PM   #7
I put a WP Gates on my car in 2014 at $122K miles. Drove it about 1200 miles the next week back and forth to South Florida. I'm now at 132K miles (retired now and don't drive it as much). No issues.
It has a composite impeller, not metal.
Old 06-11-2017, 07:47 AM   #8
water pump
I replaced motor mount shortly after I bought the car and I replaced the belt a couple of years ago when I put the UD pulley in.
Old 06-11-2017, 07:49 AM   #9
Pierburg
Yup, I went with the Pieirburg.
Old 06-11-2017, 07:55 AM   #10
Just changed out a cheap water pump with 6000 miles on it. There was play in the bearing.
__________________________
'58 356A coupe, just a driver
'00 Boxster S fair weather - daily driver
'11 Jeep Grand Cherokee Limited - winter daily driver
'92 F250 - junk hauler; previous Porsches '95 993;'08 Cayman S;'70 911E
356Guy is offline   Reply With Quote
Old 06-11-2017, 10:54 AM   #11
Yeah, I may regret my gates WP but so far so good. I certainly have had good luck with their other products.
Here's my crappy rational...
My 84 Alfa Spider used to go through OEM Bosch fuel pumps at $250+ apiece. I didn't drive the car a lot so maybe it didn't like sitting. The pumps were whiny as well.
Well, in 2007, the car strands me again and just to get it off the side of the road, I buy a no name pump in stock at local Autozone for $159. I install the pump and the first time I turn the key to on, I hear nothing. I start the car and it starts up fine. 10 years later, its still on my car and very quiet.
Fast forward to the Boxster...Somehow a $200+ OEM WP that sees to fail around 50k miles (or folk seem to want to proactively replace) doesn't seem that impressive, hence, I'll try the crappy Gates pump and see what happens.
I don't expect my rational to convince anyone else, nor am I trying to do so.
Now in retirement, I figure my car will be driven 2-4K miles a year. Age of parts will be more of an issue than use.
Either way, since this is a fairly easy DYI, if I have to replace the part in the next year or two, no biggie.
Old 06-11-2017, 02:35 PM   #12
Rennzenn
j.fro's Avatar
Check the impeller on the old pump. If it looks like the blades have any damage, flush the system forwards and backwards like there is no tomorrow. If afterwards you see any high temps, cool it off and flush again. Cracked heads are no joke.
Rennzenn
Jfro@rennzenn.com
Old 06-11-2017, 05:47 PM   #13
Motorist & Coffee Drinker
78F350's Avatar
"Thoughts on Water Pumps"
I expect that my thoughts will differ from many.
  • Many owners have had original water pumps last well over 100K miles and longer than 15 years. Many have had a variety of significant failures well short of that. These engines can be ruined by a failed pump.
  • Waiting for symptoms of a problem before changing the pump sounds crazy to me. It's not that difficult a job. The cost is not significant compared with other regular maint items.
  • Efficient/proper cooling is critical in these engines.
  • Pierburg makes the OE pumps and can be purchased at a significant discount by a savvy shopper.
  • Many other reputable manufacturers make good, adequate pumps to "OE specification" (what does that really mean) for between $100-$200.
  • My version of the internet said it is best to change them every 3-5 years. I'm cool with that.
  • Metal? or composite? I don't care. Both have modes of failure that will ruin my engine. Buy adequate quality of either and replace it short of the design life cycle.
Lastly, I know a guy that worked with a major OE parts supplier. They made the parts to the specifications of the buyer -Ford/Toyota/MB.... They also had their own production line for aftermarket. The materials and quality could be quite different between the production lines.
