12-15-2015, 01:47 PM
#21
I would replace the sump plate with a good used one & not do any racing. I have one I could sell you, but it may not get there til after Christmas. Permatex grey ultra seal works great for the sump plate only. The metal doesn't look bad. I would reassemble & check the new oil filter every 100 miles til 3,000 miles, then change & get a oil sample analyzed.
You should also get the cam timing deviation tested A.S.A.P. If the vario-cam solenoid chain wear pads have never been replaced, they should be done A.S.A.P. that's the source of most of the plastic chunks!
12-15-2015, 01:51 PM
#22
And I have had my sump plate off twice and it was not cracked like that at all.
I believe it is aluminum so I don't think it would cause any magnetic debris.
A new cover is fairly expensive I believe ($175? or some ridiculous amount), maybe you can get one from Woody or someone parting out a Boxster with a blown motor.
The FVD pan is *very* nice and sharp, also Mantis includes a bottom piece if you go mantis.
If you want to upgrade the baffle I have an EBS stainless X-51 baffle (for $100) I removed when I went to a 2 QT deep sump. The baffle worked well but as I am improving and moving to r-comps I wanted to have more protection (and I got a killer deal on the LN 2 QT deep sump that includes a version of that same baffle or else I would have kept it)
12-15-2015, 02:33 PM
#23
Steve, I would like to buy your spare EBS baffle. PM sent.
12-15-2015, 04:18 PM
#24
The color of those plastic bits is wrong for the variocam chain ramps, at least for my engine. There are 6 large ramps of blackish plastic and four small ramps that are much lighter color for the variocam.
That bashed sump plate is sad. If there isn't visible damage on the outside then it is likely, as someone pointed out above, from someone jacking the car up by the sump.
I had just a bit more metal in my oil than you're finding, and my pan was clean. I really wanted to click my heels together and do an oil change. Pulled my IMS bearing and it was just starting to flake. I went the rest of the way in and found my main bearings were totally shot.
12-15-2015, 04:56 PM
#25
The sump plate is made of aluminium. This can be welded. But you need somebody that can weld aluminium and has experience with aluminium alloys.
As flaps10 mentioned, the chain ramps at the vario cam are kind of dark brown when older. New ones are a kind of pale ebony. Hard to says from the photos which plastic debree that is. Looks like black?
Regards from Germany
Markus
12-15-2015, 05:23 PM
#26
Viper, no need to worry about your sump plate. The "cracks" you see are ridges in the die casting due to surface cracks in the die itself caused by thermal stress over time. This is normal and very common, plus there is no stress in the sump plate that would cause these to become an issue!
12-15-2015, 06:09 PM
#27
I did have both black chips (in the earlier pics) and some dark brown ones that were in the sump. I was planning on using permatex ultra black to put the sump plate back on, would anyone think thats a bad idea? It looks like it should work pretty good.
Steve, Thanks for the offer on the baffle but I will pass on that. I don't want to put money into that if I need to purchase other things. For example, I want to check cam deviations and I was going to spring for the duremetric enthusiast package, but I dont have a computer with windows on it. So now I need to buy a computer too? aghh.
I wouldn't get this sump plate welded. Its not cheap but its cheap enough to not fight with getting it welded. I will try to source a used one but if I can't, then I might just reuse this one. It didn't leak and I'll probably pull it off again in a few months so maybe replace it then?
I was planning to remove the transmission again to chase a possible rms leak so I'll pull the ims cover and take a peak at the bearing while I'm in there. If that turns out to be horrible, then I'll pul the engine and start digging. For now, I'm thinking put it back together and run it. Check cam deviations, and then go from there. I have seen threads about pulling cam covers with the engine in the car being very difficult. Does anyone know if its easier to do with the transmission out?
12-15-2015, 08:52 PM
#28
I just PM'ed you about an sump plate I have in my pile of stuff I can't throw away from an '01 2.7L that had a busted rod poking out of a hole in the case.
Different part number, but looks the same to me. Let me know if you want it and check with me if you need any other odd bits of a destroyed engine.
12-16-2015, 09:31 AM
#29
Dude I thought you were going to JB Weld that hole up and go with the 5 cylinder option.
12-16-2015, 12:15 PM
#30
Ah yes, the plan was to JB weld it and sell it on eBay as 'rebuilt'.
Viper, Here are the pics straight out of my plastic tub-of-M96. I'll give it a quick scrub before mailing:
The scrape on the bottom:
The other side of the scraped part - no internal damage.
12-16-2015, 03:51 PM
#31
Thanks f350!
Flaps, when you had this problem, was there about the same amount of metal that I am finding? Also, just curious, do you think this much metal will set off the alarm on the ims guardian? I don't have one but I am trying to find one now. I really don't want to pull the motor if I don't have to but if it comes down to it, I will definitely be following your footsteps in your rebuild thread!
12-17-2015, 10:03 AM
#32
I had this
and this
So I pulled the IMSB, with the engine in the car (transmission out). Found this:
I didn't want to take my engine out either.
These are my old main bearings.
Picture this: You and your significant other are looking forward to a nice long weekend. You're throwing an overnight bag in the Porsche, top down and taking off to where ever the road takes you.
Do you really want to spend the entire time worried that your engine is still making metal?
12-17-2015, 10:26 AM
#33
Who needs that kind of pressure and performance anxiety...?
12-17-2015, 11:19 AM
#34
That looks a lot worse than where I am at. I think if I had that much going on, then I would pull the engine. My plan now is to put another sump plate back on (one with no cracks), installing an ims guardian (just ordered one), and put it back together. I want to run the car to obtain cam deviation values and I want to do the oil cap test to see if I have a potentially failing aos. After I get this done, I will be removing the tranny to get to the oil leak that I have, and while I am in there I will see what the ims bearing looks like. If I end up removing the bearing, I will put a new one back in. I may also get the LN spin on oil filter and adapter but the ims guardian just took a chunk out of the short term budget.
12-17-2015, 11:58 AM
#35
I totally understand and can't argue with your logic at all.
12-19-2015, 04:23 AM
#36
Master Brewer
Have you considered installing a oil filter magnet? Once you do your checks and put the unit back in service I'd spring for the magnets and see what metal you can attract. Also I agree with your decision to put a spin on adapter and filter although those are more difficult to cut apart to look for debris. Whatever you do keep us posted. Good luck and hope for the best.
____________________________________
2004 Boxster S Anniversary 550 Spyder
2018 Porsche Macan (wife's ride)
2004 Ford F-150 4X4 Crew
6 Fast Bicycles
12-19-2015, 07:54 AM
#37
The magnets I feel are a little overkill. With the spin on filter, I would imagine that should catch everything, magnets or no magnets. I am going to purchase an oil filter cutter as well. It is a little more work and a little more difficult cutting the spin on apart but its worth the trouble. I have a sump plate coming on monday, an ims guardian coming on wednesday, durametric shipping out on monday, and i'm lining up a spin on adapter. I'll keep up on here with the progress. It'll be a few weeks but eventually i'll get this back together.
12-19-2015, 01:42 PM
#38
Actually, while the spin on is about 30% finer in media pore diameter than the OEM filter, your engine still generates some very fine ferrous grit that is so small it can pass through even the spin on. With a FilterMag on the spin on housing, every drop of oil passes through a strong magnetic field with every pass, removing that fine ferrous grit. One of the most common "panic" phone calls we get is from people that just installed the spin on and FilterMag, and find more black debris clinging to the side walls of the spin on housing than they expected to see. Nothing unusual, just the magnet cleaning the crap out of your oiling system; subsequent filter changes tend to show a significant reduction in this fine black debris.
12-19-2015, 04:51 PM
#39
Being that the very fine grit is passing through the spin on filter, since it's so fine, will it really hurt anything? I would agree that if it can be removed, then it's probably a good idea to do so but bottom line, is it doing any harm not removing it?
12-20-2015, 06:30 AM
#40
Master Brewer
Any grit passing through your engine equals wear. Since you have already identified metal in your oil a small investment in a filter magnet makes perfect sense. Personally, I'd rather have a device to capture the culprit than a system that tells me it's there. Money better spent. JMHO.
6 Fast Bicycles
