Old 06-17-2015, 10:36 AM   #1
ASE Certified Idiot
gtoger's Avatar
center console locked forever?
I replaced the hinge on the center console. That's great, and everything worked out fine. Then I went to try locking the console and make sure it would stay closed. Now I can't unlock it.
I don't know if something is jammed up or what. I jiggle, I push and pull... nada.
Any suggestions or words of wisdom? Perhaps this has happened to someone before.
2003 Porsche 986 Boxster S, Black / Tan
RIP: 1998 Porsche 986, Arena Red / Savanna Beige (wrecked)
1990 Pontiac Trans Am GTA .:. 1990 Corvette ZR-1 (#1930) .:. 1992 Pontiac Firehawk (#010)
1931 Ford Model A Tudor .:. 1967 Pontiac GTO .:. 1986 Pontiac Trans Am basket-case
gtoger is offline   Reply With Quote
Old 06-17-2015, 02:14 PM   #2
JayG's Avatar
crowbar???
brute force and ignorance?
Old 06-17-2015, 02:22 PM   #3
I am my own mechanic....
Timco's Avatar
I have 4-ton hydraulic spreader jaws that WILL get that thing open. You're welcome to use them.
'08 VW Touareg T-3 wife's car
Old 06-17-2015, 02:43 PM   #4
Is it actually locked, or just stuck?
Try pushing the button repeatedly while pulling up on the lid with light to moderate force.
Old 06-17-2015, 03:01 PM   #5
bc993's Avatar
Sounds Like the same designer engineered the Boxster Console that did the Glove Box in my 993 what a Cluster F design of the latch mechanism.
bc993 is offline   Reply With Quote
Old 06-17-2015, 03:27 PM   #6
Does the key not turn, or does the button not push?
Or does the button push, but it doesn't unlatch?
Nothing in mind, just trying to clarify while we think it through. I think ParticleWave's extra jigglin' and crankin' and pushin' is certainly worth a try, these little consoles seem a bit...cheap.
CraigM is offline   Reply With Quote
Old 06-17-2015, 07:00 PM   #7
ASE Certified Idiot
gtoger's Avatar
I found the solution!
Show the problem you're having to a co-worker who can help you out. As it turns out, the co-worker doesn't have to do anything other than look at you like you've got 3 heads as you thoroughly describe the problem only to demonstrate the trouble and the key just turns and moves to the unlock position just as it should.
That takes care of the issue right away.
Just for reference (not that it matters anymore) the button would push, and the key went in and out, but the key would not turn. The car just wanted to make me look silly is all. Some sort of German joke.
Old 06-17-2015, 07:17 PM   #8
Haha! Or maybe it heard Timco's suggestion...
