Old 04-24-2014, 10:24 AM   #1
Rob175's Avatar
Vents blowing foam pieces
Just wondered if others have had the same happen. I have little pieces of foam (insulation) blowing out of the dash vents. It's meduim dark gray in color and I assume its just the foam used to insulate the vents. Every once in awhile a few will blow out. I'm not concerned since I assume some deterioration is to be expected with a car that is 16 yrs old (98' standard Boxster w/ 72,000 miles)...i assume just normal due to age.
Rob175 is online now   Reply With Quote
Old 04-24-2014, 10:29 AM   #2
Rob175's Avatar
Nevermind.....I should have done a thread search first. Seems its a common problem with aging cars....for now I'll ignore it since the system seems to be working fine. Best to leave it well enogh alone.
Old 04-24-2014, 09:09 PM   #3
nieuwhzn's Avatar
Cheap seal of air mixing door, no problem.
Just keep your mouth shut while driving
nieuwhzn is offline   Reply With Quote
Old 04-25-2014, 07:24 AM   #4
Learned that lesson back in my motorcycle days!
'99 black 986
Old 04-25-2014, 10:07 AM   #5
tanque55's Avatar
Welcome to the old car club! Foam deteriorating and blowing out the vents is pretty common in cars from warm climates. My F150 started doing that after 7 years.
tanque55 is offline   Reply With Quote
Old 04-25-2014, 10:32 AM   #6
Multi-Boxer Driver
Deserion's Avatar
My '04 is doing this as well. Still gets chilly inside so I'm not worried.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 04-25-2014, 01:18 PM   #7
BIGJake111's Avatar
part of having a car haha... mine does it.. just glad it isnt a 2 year old car my sister got a civic as her first car and it was blowing foam by 2010 with the car being a 2008
Old 04-25-2014, 07:21 PM   #8
1999 base
Meir's Avatar
Just in case you are very bored and have nothing to do over he weekend.
http://986forum.com/forums/diy-project-guides/37246-c-evaporator-replacement-c-foam-flakes.html
