Old 03-20-2013, 11:41 AM   #1
Original pump: 130,000
replacement: 10,000
Mine crapped out last week.
Wret is offline   Reply With Quote
Old 03-20-2013, 12:01 PM   #2
2000 base.
3 oem pumps have failed, worm impellers on each.
they have failed like clockwork @ 30,000 mi or 3 years.
so, i'm on pump #4 @ 96,5000 mi.
jotoole is offline   Reply With Quote
Old 03-20-2013, 12:13 PM   #3
Carnut
AndyA6's Avatar
'04, 55,000mls, original pump
'14 Boxster
Old 03-20-2013, 12:31 PM   #4
Moderator
Mine lasted 12 years, with 72,000 miles accumulated before being replaced.
Old 03-20-2013, 01:39 PM   #5
2001 base with 42,000 when the original water pump started to leak. Changed it plus the coolant tank at the same time.
sailing1 is offline   Reply With Quote
Old 03-20-2013, 02:33 PM   #6
The variability from one car to the next is amazin', eh?
Old 03-20-2013, 02:54 PM   #7
Yep
A sure sign of lack of quality control.
Old 03-20-2013, 05:34 PM   #8
Spinnaker's Avatar
2000 S
111,000 miles
3rd pump
Old 03-20-2013, 05:45 PM   #9
01 2.7L manual trans.
121K miles on original. slight bearing wear, replaced it
11K on new pump.
sb01box is offline   Reply With Quote
Old 03-21-2013, 09:25 AM   #10
How many water pumps has your 986 been through?
What are the symptoms of a failing pump?
rondocap is offline   Reply With Quote
Old 03-21-2013, 09:44 AM   #11
2002 S 86,000 original pump
sfoster13 is offline   Reply With Quote
Old 03-21-2013, 11:00 AM   #12
Replaced at 50k as preventative mainanence.
Original was still perfect.
SF-Rockster is offline   Reply With Quote
Old 03-21-2013, 03:17 PM   #13
jsceash's Avatar
None yet 52,245. I have one sitting in the garage waiting for 3.6 LN block to be returned.
Old 03-21-2013, 04:02 PM   #14
Ckrikos's Avatar
My shop is replacing mine. I had a bunch of work done then when I drove it home the water pump apparently died. my temp was running a little hotter than normal and when I parked my car it vented all of the fluid. Thing is that coolant also came out of the filler end through the cap. I'm wondering if I should change out the reservoir too. I assume that changing out the serpentine belt and pulley must have messed with the water pump causing it to fail. Btw mine was at 50k miles.
LB/GG/MB 02 2.7 sold
MB/GG 02 996TT
Old 03-21-2013, 04:39 PM   #15
Theoretical propagandist
Eric G's Avatar
Replaced the original last year at 90K and it was due.
Old 03-21-2013, 06:11 PM   #16
Don't want to jinx mine so I'm not saying!
Old 03-21-2013, 06:13 PM   #17
Ok...I bought the car in July 2008 with 75K miles. Now have 107K. I've changed coolant at ~95K and coolant tank shortly thereafter.
Old 03-22-2013, 06:01 PM   #18
Squozen's Avatar
10 years and coming up to 39k kms, still on the original water pump. I have a replacement sitting in the cupboard and I'll fit it eventually.
Squozen is offline   Reply With Quote
Old 03-22-2013, 08:32 PM   #19
Skrapmot's Avatar
Original, just hit 82k.
Old 03-23-2013, 10:59 PM   #20
02 base, 75k and original pump
02 Boxster (DD sans kids)
08 Corvette Z06 (Track car)
