01-18-2013, 09:53 AM
Help!!!! Door Problems
Okay, I've owned my 99' Boxster for about two weeks, a few days ago I noticed that when I opened the drivers door the window would go down like normal then return up and 'clip' the jam so I had to close it with my hand on the latch to get it to close correctly, I've learned to live with that as I'm low on money after the down payment, insurance, etc. but now when I go over a small bump the interior lights will turn on as if the door is ajar. Because my car thinks it's door is open my passenger door wont lock and the drivers I have to do by hand as the keyless lock stopped working this morning I am assumeing because of the door.
it's a 99' Arctic Silver, Black interior, Black top, Boxster. Thank you for any help you might be able to give. I'm hoping it's something stupid that I messed up and can fix by closing the door and opening a certain number of times or disconnecting the battery.
01-18-2013, 10:04 AM
1999 base
very common issue with boxster.
you will have to replace the micro switch on the door lock mechanism.
http://986forum.com/forums/performance-technical-chat/38044-door-locks.html
01-18-2013, 10:07 AM
Indications of a failed door locking mechanism, there is a micro switch that fails on these units.
Porsche Boxster 97-04 - Panels & Doors - Page 1
Jäger
300K Mile Club
01-18-2013, 10:38 AM
Thank you!! Looks like it's going to be a 300 fix  , any tips for locking the doors or a temp fix? thank you for the help and quick responses. Was really hoping it was my fault. Now I don't have the money because, well, first Porsche!!!!
01-18-2013, 11:06 AM
1999 base
on second thought, when you describe the scenario, is that from inside or outside the car ?
01-18-2013, 11:10 AM
outside of the car is when it wont lock, inside while driving is when I have the problems with the lights, when using outside handle the window goes right back up but on inside I think it works normally.
01-18-2013, 11:13 AM
01-18-2013, 11:24 AM
It does sound as if the micro-switch has failed. Once the car doesn't sense correctly the actual position of the window all sorts of weird symptoms occur. One question: does the window behave in a similar way on the passenger side? The reason for the question is to narrow down which micro-switch failed. Each door has its own set.
01-21-2013, 08:00 AM
Thank you for the offer, the shop in town quoted me $370 eek. I've never been good with working on cars and stuff but I happen to know another mechanic from Porsche and he agreed to help me install the $50 part myself. Before I order this I noticed the doors are loose, like I can lift them a little with the handle while open. Maybe this is the problem? It does explain the lights going on and off with bumps in the road. I'm going to call the local shops and see how much it would cost to just tighten them since I have no access to the hex tool in the awkward slot it is in.
