Old 01-18-2013, 08:53 AM   #1
Help!!!! Door Problems
Okay, I've owned my 99' Boxster for about two weeks, a few days ago I noticed that when I opened the drivers door the window would go down like normal then return up and 'clip' the jam so I had to close it with my hand on the latch to get it to close correctly, I've learned to live with that as I'm low on money after the down payment, insurance, etc. but now when I go over a small bump the interior lights will turn on as if the door is ajar. Because my car thinks it's door is open my passenger door wont lock and the drivers I have to do by hand as the keyless lock stopped working this morning I am assumeing because of the door.
it's a 99' Arctic Silver, Black interior, Black top, Boxster. Thank you for any help you might be able to give. I'm hoping it's something stupid that I messed up and can fix by closing the door and opening a certain number of times or disconnecting the battery.
RussCatalano is offline   Reply With Quote
Old 01-18-2013, 09:04 AM   #2
1999 base
Meir's Avatar
very common issue with boxster.
you will have to replace the micro switch on the door lock mechanism.
http://986forum.com/forums/performance-technical-chat/38044-door-locks.html
Old 01-18-2013, 09:07 AM   #3
Jager's Avatar
Indications of a failed door locking mechanism, there is a micro switch that fails on these units.
Porsche Boxster 97-04 - Panels & Doors - Page 1
Jäger
300K Mile Club
Old 01-18-2013, 09:38 AM   #4
Thank you!! Looks like it's going to be a 300 fix , any tips for locking the doors or a temp fix? thank you for the help and quick responses. Was really hoping it was my fault. Now I don't have the money because, well, first Porsche!!!!
Old 01-18-2013, 10:04 AM   #5
1999 base
Meir's Avatar
i think you can get just the micro switch insted of the whole assembly.
Pelican Parts - Automotive Parts and Accessories - Porsche & BMW
there is another one located on the external door lever mechanism.
you will be able to diagnose it better with the door cover removed.
you might be able to solve the issue by simply cleaning it with electronic cleaner spry.
edit: links for parts.
Micro switch on door lock mechanism (part 20):
http://www.********************************************.com/porsche-parts/986-97-04/807-10.php
Micro switch on door external lever (part 14):
http://www.********************************************.com/porsche-parts/986-97-04/804-20.php
Old 01-18-2013, 10:06 AM   #6
1999 base
Meir's Avatar
on second thought, when you describe the scenario, is that from inside or outside the car ?
Old 01-18-2013, 10:10 AM   #7
outside of the car is when it wont lock, inside while driving is when I have the problems with the lights, when using outside handle the window goes right back up but on inside I think it works normally.
Old 01-18-2013, 10:13 AM   #8
Old 01-18-2013, 10:24 AM   #9
thom4782's Avatar
It does sound as if the micro-switch has failed. Once the car doesn't sense correctly the actual position of the window all sorts of weird symptoms occur. One question: does the window behave in a similar way on the passenger side? The reason for the question is to narrow down which micro-switch failed. Each door has its own set.
