Old 08-27-2005, 05:56 AM   #1
deliriousga's Avatar
Unhappy Smobek...smobek! Tons of smoke! Updated at the end.
Smokin' like crazy at start-up (even after just 2 hours) and the belt started squealing constantly. I'm goin' in and hopin for the best, but if anyone has had an oil leak that hit the belt, please let me know where it came from.
TIA!
1966 Wife White/Brown Top
Old 08-27-2005, 06:56 AM   #2
Brucelee's Avatar
Does it just smoke at start up or does it keep on?
Is this black or white smoke?
Old 08-27-2005, 07:14 AM   #3
White smoke, just at start up but not the normal poof, it's a huge cloud. I tried to take pics, but the camera couldn't see through the cloud.
She's burned off a pint of oil in the last three days at start up.
I believe I've found the problem, though. The oil filler tube collapses under vacuum. That's what was making the squealing noise, not the belt. I'm lucky because we have two Porsche dealers here within 40 miles of my house so hopefully one of them will have it so I can keep her on the road.
Old 08-27-2005, 05:26 PM   #4
Rail26's Avatar
Delirousga...I have an idea. Since you are going to get the problem fixed anyway and there is a lot of smoke coming out, I suggest putting a beef brisket behind the pipe and putting a few drops of liquid smoke in the oil res. and making a little barbecue. Just a thought...
'05 987 Basalt Black/Sand Beige
5 spd, 18" wheels
AH-64 Apache
RC-12 Guardrail
RC-7 Crazy Hawk
"If the wings are traveling faster than
the fuselage, it's probably a helicopter--
and therefore, unsafe" --Unknown
Rail26 is offline   Reply With Quote
Old 08-28-2005, 07:18 AM   #5
Well, the oil filler tube didn't take care of the problem. Took it out last night after working on it all day and here's what I found:
The smoke comes out of the exhaust. I don't see it coming from the engine bay or around the exhaust like it's leaking on something then burning. It's like too much oil is being pumped into the cylinder(s) and it's burning it off. If it sits for about 2 hours, about a cup of oil will be burned off at start-up. The amount of smoke is so big if you back into it you're completely blind, like sitting in the middle of a cloud. I'll try and post a picture in a bit if I can.
I was completely wrong about the squeal. There is no oil on the belts at all. I could only get it to squeal with the covers on. I guess the engine does not get hot enough when it's wide open so I still don't know what's causing the squeal. Since they both started happening at the same time, I'm guessing they're related.
Does anyone know if you can see the oil dripping if you have an RMS failure? I was looking around at everything and there is no visible oil anywhere. I looked around where the RMS should be located and it's all sealed so I don't know if you can see the leak or not.
Any suggestions would be greatly appreciated! I'm flying blind right now and we won't drive it until it's figured out. Working on the clutch in the 928 today since I should be able to finish it and keep 2 cars on the road.
TIA!
Old 08-28-2005, 11:15 AM   #6
Brucelee's Avatar
If you have a RMS leak you will know it. It will drop straight down and should not be connected to smoking like you described in any way. The oil will be on your garage floor.
If that smoke is white-ish, I would say you have a breach in the coolant to combustion chamber. This would indicate a head gasket I believe.
If the smoke is black, then your breach is more serious, oil to the combustion chamber.
Time for a service dept visit.
Old 08-28-2005, 01:57 PM   #7
Deliriousga, Have you checked your Oil Separator for leaks/cracks, or the Spark Plug Tube O-Rings for leaks???
spine911 is offline   Reply With Quote
Old 08-29-2005, 06:31 AM   #8
Thanks for the info on the RMS. That helps isolate it for me.
I'm going to do some more diagnostics before going to a service dept. I'm willing to do the head gasket and most other things myself. The only thing I won't DIY is inside the chamber (valves, pistons, etc.) because I don't have all of the special tools and they're pretty pricey.
Old 08-29-2005, 07:16 AM   #9
good luck deliriousga. Let us know what you found out. Hope to see your
yellow porsche around town soon.
fefyfo is offline   Reply With Quote
Old 08-29-2005, 08:00 AM   #10
This might seem like an odd question but what does the smoke smell like..... oil of course will smell like.... well oil but coolant has it own unique sweet smell. Often after a repair it takes awhile for the oil/coolant to be burnt off from the exaust system. If you feel safe with the car just take it for a good drive and see what happens next time you flash it up.
wvicary is offline   Reply With Quote
Old 08-29-2005, 08:44 AM   #11
It smells like burning oil. Like you spilled it on the manifold. I took it out Saturday after I replaced the oil filler tube and the same thing happened. I started it 4 times that evening to/from church and to/from the movies and the same cloud happened every time.
I was referred to a few good threads on renntech.org concerning the oil separator so I think I'm going to start there for now. I'll report more on what I find as I go along.
Thanks!
Old 09-08-2005, 12:55 PM   #12
She's back on her feet.
I replaced the oil separator last night and it seems to have taken care of the problem.
I'll keep an eye on her over the next few days and report back if it didn't completely fix the problem.
Old 09-08-2005, 05:21 PM   #13
Talking
Oil Separator leak(oil leak on Right side of engine) is the number 1 culprit for leaks causing significant smoking and oil burning smell...Number 2 culprit could be your Spark Plug Tube, or Valve/Cam Cover Gasket(oil leak on either side of the engine) which causes oil burning smell, and smoking(if leak is significant).....I highly doubt your problem being a Head Gasket Failure or Engine combustion problem...I definitely think its one of the above(oil leak, then drips to the exhaust manifold causing the smoking).
Old 09-09-2005, 07:59 AM   #14
Perfectlap's Avatar
boy you must be heavy sleeper. The minute I see that much smoke I'm off to the Porsche mechanics ASAP. I need to sleep well at night!
BORN: March 2000 - FINLAND
Old 09-09-2005, 10:22 AM   #15
It wasn't driven for 1 1/2 weeks while we waited for parts and time to put it in.
