Old 07-05-2005, 12:01 PM   #1
Ignition key duplication question
Hi all,
I am going to be moving in the near future, and I will be turning the key over to the movers. I only received 1 key when I bought the car, and want to make sure I have an extra in case one gets lost in transportation of the vehicle. I have the vehicle IPAS info which has the key learn code, immobilizer code, ignition lock code and programming code.....Not sure which of these is needed, but what would be the best way of going about getting another key? Hopefully something in a timely manner as I am moving in the next few weeks!
Thanks,
Lou
1998 Guards Red Black/Black 5 sp.
Work done '06 :Replaced bad hose and clamps from reservoir tank
oil change and filter
replaced seals on both cam covers
brakes bled and refilled
Replaced bent rear right lower control arm
Front air dams and 3 underbody panels replaced
Halogen headlamps replaced
bigislandboxster is offline   Reply With Quote
Old 07-05-2005, 01:55 PM   #2
Brucelee's Avatar
Talking
Go to the dealer with proof of ownership.
They can order you either a valet key or a remote and key.
If you order the remote, they will need to program it after you get it from parts. You need the car there for that process.
Assume $270 list for remote and key, and then about $80 for programming.
Or, the valet key is about $115 with of course, no programming.
You cannot get these keys at the corner locksmith.
Good luck on the move.
Old 07-05-2005, 02:21 PM   #3
Thanks a bunch .......I have a "lease special" , so only the valet key....115.00 doesn't sound bad....
Old 07-05-2005, 06:11 PM   #4
Brucelee's Avatar
Talking
I would agree!
Old 07-06-2005, 06:18 AM   #5
Send a message via AIM to jiggysubman
bigisland, are you moving off the island? Where to?
Never use a big word where a dimunitive one will suffice.
97 Guards Red
82k miles
jiggysubman is offline   Reply With Quote
