Old 07-03-2011, 07:54 PM   #1
Changing Fan Series Resistor
I just received my cooling fan series resistor. When I looked at it, there are 2 wires without any connectors, just wires that has been covered with lead solder....
Question: what do I need to do in order to change the series resistor ? Do I need to solder these 2 wires to somewhere or do they snap into place somewhere ? Do I need to remove the entire fan housing ?
I just wanted to be prepared before opening up. Looking at the pictures for the radiator install, it would look like the entire fan housing needs to come out in order to replace the resistor ?
Thanks for any tips.
shlim8 is offline   Reply With Quote
Old 07-04-2011, 12:44 PM   #2
You have to cut the wires coming from the fan motor and splice the wires from the new resistor into them. Leave the motor wires as long as possible. I joined the wires with crimp connectors that I filled with rtv silicone to keep out the weather.
While you can change the resistor by just loosening the wheel liner, its highly suggested that you remove the bumper cover and thoroughly clean the radiators if you haven't done it recently.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 07-04-2011, 05:13 PM   #3
San Rensho, thanks for the tip. Hmm, kind of strange design to not make the resistor a plug in replacement.
I do intend to remove the bumper to clean the radiators and to add grills to reduce the amount of junk clogging up the radiators.
Old 07-04-2011, 06:05 PM   #4
The fewer connections out in the weather, the less the potential for shorts, corrosion and the like..........
Old 07-05-2011, 11:14 PM   #5
True, but since this is a common failure item, after replacing the original, the protection against the elements might be worse off than if Porsche had just designed waterproof plugs to faciliate the replacement.
Anyway it's not a big deal, I'll probably solder the wires, use shrink plastic insultation and silicon the whole thing for protection.
