Old 07-06-2011, 12:14 AM   #5
shlim8
The fewer connections out in the weather, the less the potential for shorts, corrosion and the like..........
True, but since this is a common failure item, after replacing the original, the protection against the elements might be worse off than if Porsche had just designed waterproof plugs to faciliate the replacement.
Anyway it's not a big deal, I'll probably solder the wires, use shrink plastic insultation and silicon the whole thing for protection.
shlim8 is offline   Reply With Quote
