Old 02-22-2010, 09:25 AM   #1
the easiest thing to do is to unplug the swith altogether. The electronic latch will still work. If your light does not go on as it should the the switch is bad. I may be like mine that was shorting the battery.
In any case, it takes a sec, pull back the carpet around the latch, reach in and unplug.
james
2002 S
jhandy is offline   Reply With Quote
