Old 02-22-2005, 11:12 AM   #7
Perfectlap's Avatar
have you checked to see if your lug nuts have been correctly torqued?
If you have the bearing repacked/replaced make sure they apply the right amount of torque. Most garages use the impact gun and never check to see if too much pressure has been used.
Also maybe check the inside of the tires at a wheel and tire shop. I had a used car once and the previous owner didn't have all the flat-fix-in-a-can gunk removed and at about 50mph it produced a hop with an anoying womp womp sound.
BORN: March 2000 - FINLAND
