10-24-2008, 08:32 AM
Bizarre question
Hi all
This is going to sound quite bizarre but do any of you know if you can fit a tow ball to a Boxster? If so, how, since the exhaust is in the centre?
Cheers
10-24-2008, 08:47 AM
10-24-2008, 09:01 AM
Superb. Thank you very much. It is much appreciated. Now i just have to decide on a boat!
10-24-2008, 09:20 AM
Tow a boat!!!  Maybe a Laser or a sailboard!
10-24-2008, 09:53 AM
Even a Laser and all the equipment would seem like a lot...
10-24-2008, 10:22 AM
Willwood System has a hitch and the same receivers work for Will's bike and luggage carriers too.
http://www.willwoodsystem.com/
2003 Boxster - Sold but not forgotten
10-24-2008, 04:45 PM
I used to tow quite a bit, including a 26 ft Sundancer @ 6500 lbs behind a Mercury Mountaineer which I thought was pushing it. I wish you the best of luck but think the Boxster will suffer greatly towing anything, it's just not designed for that in any regard.
10-24-2008, 05:23 PM
There Is No Substitute.
I read a alot about this a while back. In my opinion th ebest design is this one:
http://members.rennlist.com/1porsche/Trailer_Hitch.html
I have seen people towing two jet skis with a Boxster, but most people tow a trailer with autocross gear. The weight of the trailer is not the problem, its the tongue weight you need to worry about.
10-25-2008, 06:14 AM
That's only partially true, sure the tongue weight is very important in it's reaction with the suspension, I had to put air shocks on the truck to compensate for how soft a Mountaineer is sprung. However, where I disagree with you is in negotiating hills, you will feel the entire towing weight going up or down.
10-25-2008, 09:37 AM
I agree, you will definitely feel it, but if your trailer is less than 1000 lbs. you shouldn't have a problem. YIt depends on the trailer's weight, but if the trailer is light it would be no different than having a passenger and both trucks completely full.
10-27-2008, 08:33 AM
Thanks for replies guys. It would only be a small boat and more likely a jetski. Do you think this would still be a problem?
10-27-2008, 08:47 AM
I doubt you will have a problem with a small boat or jetski. If it is mostly flat and you aren't driving up a mountain you should be fine. Post a picture when you do it.
10-27-2008, 10:37 AM
Will do.
Thanks again to one and all!
