Old 07-15-2007, 07:50 AM   #5
Originally Posted by Adam
If you are worried about rust, you could treat the area with a rust preventative. You could find those at auto-parts/hardware stores. What exactly hit on the underside of the car? I believe many suspension bits like the control arms are actually aluminum so rust may not be an issue anyway.
Adam,
What I scratched was a low (probably the lowest) clearance part of the car. It looked like a tubular metal bar that attached itself near both of the rear wheels. It is the part with the white "made in germany" sticker. Do you know what part I am attempting to describe is?
Also, do you advise that next time I get the oil changed or new tires, I have them spray that area?
Thanks for the advice!
JCL12 is offline   Reply With Quote
