Old 07-30-2024, 08:48 AM   #2
78F350
Motorist & Coffee Drinker
78F350's Avatar
Originally Posted by martinef1963 View Post
...Is there a way I can manually put the window up until I can break the door down and check the window motor? ...,
If it failed in the process of going down, my guess would be a bad regulator. If the regulator cable isn't badly jammed you can move the window by hand while working the switch.
This video is about the door latch, but it will be helpful for removing the door panel:
