Old 07-05-2021, 01:37 PM   #1
elav
It wont work, at least not 100%. I know, I came up with the relay wiring. You would lose the low setting.
Now, if it is the relay and you want to replace it cheaper then the factory one let me know. I designed a circuit board setup using standard 30 amp relays that is much cleaner then the one from Help Me DIY.
Thanks - unfortunately I won't get to this today but I'll do some debugging and let you know if I require your set up. Great info on this board!
'98 Boxster 986
'87 911 Carrera Cabriolet
elav is online now   Reply With Quote
