Old 03-21-2020, 03:13 PM   #1
maytag
Who's askin'?
maytag's Avatar
Originally Posted by SpIcEz View Post
Ive reviewed the diagrams, but I cant follow one of the lines (green arrow) unless I remove the intake manifolds.
Off the Y shape, I see one side going to the reservoir and the other to the check valve.
Where I'm pointing the green arrow in the picture (same hose as green arrow above), are those 2 hoses supposed to be connected together?
Maybe I broke it off while removing the starter??
Thanks for any insight.
Chris
Where does the other end of that hose go to? Iirc, it should go to the solenoid mounted on the fuel rail, left side. If that's it, then yup, I think you found it.
I've never tried to buy plastic vacuum hose like that, but I'd think a sleeve of rubber hose would patch that together quite nicely.
