Old 02-26-2019, 08:56 AM   #11
PaulE
The best, easiest method I I've found, is to take it to the racetrack. It'll overflow all of that fluid onto the top of the motor, and then you can replace it all!
Last time I had the intake off, I added a hose to the overflow, running it down under the car, instead of the little stubby hose that the factory puts, dropping the fluid onto the top of the motor.
Did you add a catch can for the track or are the overflow amounts so minuscule it isn't necessary?
