Thread: Crazy Horn!!
Old 01-01-2014, 11:29 PM   #1
Brad Roberts
Brad Roberts's Avatar
If 4 spoke.. you have 4 torx screws that you access from behind the wheel. Unscrew them and the air bag/center of the wheel comes out. The frame sits inside the steering wheel and "floats" the air bag.
I HIGHLY SUGGEST YOU DISCONNECT THE BATTERY!! <<<<< Am I clear??
If you decide to do this.. BEFORE you disconnect the battery, make sure you have the radio code
The torx screws can be difficult to remove. You'll have to turn the wheel depending on how long your torx screw driver is.. they are kinda buried into the back of the wheel.
Engine Builds, Transmission Builds, Engine Conversions, Suspension Installs, Suspension Tuning, Driver Coaching, Data Acquisition, Video, SCCA/PCA/POC/NASA/GRAND AM/ALMS.
We have worked with amateur and professional drivers for over 26 years. In house machinist, In house fabrication. Our cars, our parts, our engines, our transmission's run nationwide at events every weekend. We work side by side with industry names developing parts.
Brad Roberts is offline   Reply With Quote
