Old 03-28-2017, 04:29 AM   #1
Boxster losing power
Hi Forum,
After the winter stand stil I realized that my 2,5 boxster 1998 had a hard time raving beyond 4000 rpm at load.
It has no hesitation, misfire or anything else and it starts idle and actually drives quite smoothly.
I notised hat I have two codes which keeps coming back P1123/25 Oxygen sensing limit adaption range 1 ( cyl 1-3) and ( 4-6)
Consequently we did put it on a Dyno , see photo below
were sad results, only 122HP at 5000RPM
The guy stoped the dyne run here explaining that it had sever fuel starvation.
( he had a probe in the exhaust, and I guess that he meassured it to be lean)
I guess that that matches the codes.
Is there any obvious places to look except for the fuel filter.
BR
KIm
barthol is offline   Reply With Quote
Old 03-28-2017, 06:15 AM   #2
steved0x's Avatar
Look at the Mass Air Flow Filter (MAF) - when this part starts to fail, it often exhibits the symptoms you describe. A quick test is to disconnect the sensor and let the car run using a default map - if it runs better, you know you have a failing MAF sensor.
Porsche Boxster Mass Air Flow Sensor (MAF) Replacement and Troubleshooting - 986 / 987 (1997-08) - Pelican Parts Technical Article
Old 03-28-2017, 07:14 PM   #3
Agree - replace fuel filter and do the MAF-disconnect test.
But maybe time for a big service?
If you didn't put Stabil in the fuel, it may have gelled ?
Fuel pressure regulator ?
If the O2 sensors are getting 'old & lazy' ,changing them and the plugs may help.
Air filter?
Old 03-30-2017, 08:45 AM   #4
Hi
Thanks for the advises.
Fuel pressure checked today by my mechanic , and it was OK.
The Airflow through the MAF was according to the Mechanic measured to be too low .
I guess that this will reduce the amount of injected fuel accordingly?
New one is ordered and it will be installed tomorrow.
BR
KIm
Old 03-30-2017, 11:05 AM   #5
Porsche "Purist"
Paul's Avatar
Make sure rodents have not built a nest in your air filter.
1987 924S. 2002 996TT. PST-2
Old 03-30-2017, 08:39 PM   #6
air filter is brand new:-)
br kim
Old 03-31-2017, 10:30 AM   #7
Bart,
Slow down.
The only piece of diagnostic data (not performance data) you've got is :
"The Airflow through the MAF was according to the Mechanic measured to be too low "
Please don't feed us info piecemeal and partial. If the Mechanic has done a complete test ,give it to us - the RKAT,FRA ,fault codes - all of it. Otherwise this is just random speculation which will waste time(ours) and money (yours).
Airflow - we need the actual value in gramms.
Meanwhile remove the airfilter and retest briefly .Big change ? Check/clean the TB .You are looking for obstructions.
Please tell us you don't have a K&N (or similar) filter fitted.
Without a Durametric connected and freeze frame data to post this will be difficult to diagnose logically and methodically.
Old 04-03-2017, 06:29 AM   #8
Power is Back
Hi Gelbster,
Airflow was 90 ltr/sec and the Engine incl filter is all stock.
Anyway the MAF was exchanged and all the power is now back 213 HP /270 NM
Not bad for a 19 year old car which has done 156.000 km :-)
BR
KIM
