Old 02-16-2017, 05:41 AM   #1
Bad engine mounts?
Hi.
I recently bought a 1999 Porsche Boxster 2.5 with 60k miles on it.
This is my first Porsche and I'm completely in love
However, I have an issue that worries me a bit.
When I accelerate hard in 1st and 2nd gear (sometimes 3rd) and shift upwards, I get a hard clunk from what feels like the entire chassis. So I figured that I may have a bad engine mount.
Also if I get wheelspin during acceleration on wet roads it feels like the tyres is slipping and gripping in an endless cycle. This causes the same type of hard/violent clunks as when I shift, but in perpetuity instead.
Can you brilliant Porsche minds provide me some insight on this issue?
Here is a picture of it
IceBlitz is offline   Reply With Quote
Old 02-16-2017, 06:07 AM   #2
98 Arctic silver 986
tommy583's Avatar
Sounds like a front engine mount to me. Mine sounded and felt like a bad CV joint if I was on the gas during a hard turn. It also had a clunking if I shifted really hard sometimes.
Old 02-16-2017, 06:36 AM   #3
On the slippery slope
JayG's Avatar
A constant clicking when the car is moving is likely a CV
A clunk when up shifting is likely a front motor mount
Lots of threads on both
2004 996 Targa Tip
Instructor - San Diego region
Old 02-16-2017, 06:55 AM   #4
Yep, that is a classic symptom of a failing motor mount. While you're under the car, also check the transmission mounts for any leaking. The trans mounts are filled with a viscous dampening fluid and if there is any leakage, they should be replaced.
Does your car have traction control? My Boxster has TC and will do something similar as the computer applies and releases the brakes to try to control wheelspin. If no TC, then hard to say what might be happening and maybe someone else has some ideas.
By the way, I like the 2001-2003 wheels!
Old 02-16-2017, 08:51 AM   #5
Check the 'use by' date on the tires. They may have good tread but if they are very old ,they become hard and less grippy.
Old 02-16-2017, 07:59 PM   #6
Bad motor mount may also presents itself as a resonance at around 3,000 rpm.
Old 02-17-2017, 06:48 AM   #7
If you do change out your motor mount, spend more and swap out the water pump. You'll be right there and it's worth it...
Old 02-20-2017, 04:45 AM   #8
Thanks for the good replies, guys
Do you know where I can buy a cheap OEM front engine mount?
Old 02-20-2017, 06:40 AM   #9
JayG's Avatar
No need to buy the entire mount, just the insert. Remove the old one and have the new one pressed in
Look online
Get the 987/997 insert, but you will need the new side rubber things as they are a different thickness
Lots of threads on this. The search function works well
IIRC, the insert is around $40
2004 996 Targa Tip
Old 02-20-2017, 06:44 AM   #10
Have you tried Pelican Parts who host this forum?
1941 Dodge Luxury Liner Coupe
