Old 02-16-2017, 06:55 AM   #4
thstone
Originally Posted by IceBlitz View Post
When I accelerate hard in 1st and 2nd gear (sometimes 3rd) and shift upwards, I get a hard clunk from what feels like the entire chassis. So I figured that I may have a bad engine mount.
Yep, that is a classic symptom of a failing motor mount. While you're under the car, also check the transmission mounts for any leaking. The trans mounts are filled with a viscous dampening fluid and if there is any leakage, they should be replaced.
Also if I get wheelspin during acceleration on wet roads it feels like the tyres is slipping and gripping in an endless cycle.
Does your car have traction control? My Boxster has TC and will do something similar as the computer applies and releases the brakes to try to control wheelspin. If no TC, then hard to say what might be happening and maybe someone else has some ideas.
By the way, I like the 2001-2003 wheels!
