Old 01-04-2017, 06:00 AM   #1
Quick Question: Brake Pad Retainer Kit
I'm getting ready to order new pads and rotors and was wondering if I can reuse the pins and retainers. At over $120 for a full set, I would prefer to put that money to use in higher quality pads and rotors.
OTOH, I want to do the job right, so if it's wise to replace the hardware, so be it. Thanks!
Need_for_speed is offline   Reply With Quote
Old 01-04-2017, 06:26 AM   #2
There Is No Substitute.
rick3000's Avatar
You can reuse the pins/retainers, there is no reason to replace them unless they are broken.
Old 01-04-2017, 07:20 AM   #3
steved0x's Avatar
I have reused them, but also put in a new set every couple of years, I just did new rotors and pads all the way around and I put new hardware in. However I used Centric parts which are like $7 a set:
2000 PORSCHE BOXSTER 3.2L H6 Disc Brake Hardware Kit | RockAuto
More Information for CENTRIC 11737004
More Information for CENTRIC 11737008
Old 01-04-2017, 08:04 AM   #4
Thanks Steve! I know one of you guys would find that part cheaper!
After a thread search, I'm now finding that it's recommended to replace the caliper bolts as well when you do a rotor changeout.
Old 01-04-2017, 08:15 AM   #5
And put a dab of grease/oil/ antisieze on the pin
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 01-04-2017, 04:16 PM   #6
On the slippery slope
JayG's Avatar
All you really need is the pin anyway
2004 996 Targa Tip
Instructor - San Diego region
Old 01-04-2017, 05:29 PM   #7
Its the spring that tends to corrode.
1941 Dodge Luxury Liner Coupe
Old 01-06-2017, 02:09 PM   #8
lkchris's Avatar
You can reuse the pins and retainers, but you can't reuse the screws that mount the caliper to the hub. Porsche specifies replacement only ... once is enough to stretch them.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
Old 01-07-2017, 04:58 AM   #9
Ikchris is right. I had to remove my calipers at the track, the bolts started to strip out when removed.
Get the caliper studs from Tarrett. Well worth the $
Old 01-07-2017, 10:28 AM   #10
seningen's Avatar
Anti seize the caliper bolts... especially if you track the car.
Then use proper torque when tightening.
I've been doing this for years without any problems.
Mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is offline   Reply With Quote
