Old 10-26-2010, 07:07 PM   #1
Pic of removed airbox?
Hi guys,
I am planning on making my own airbox and would like to know if anyone has any pictures of the stock unit after its been removed?
Failing that, are there any hints/tips on how to remove it? I have heard that you have break it to remove it?
Sam
sparker is offline   Reply With Quote
Old 10-27-2010, 03:48 AM   #2
Jaxonalden's Avatar
I can get you a picture of mine tonight (27 Oct) when I get back from work.
Old 10-27-2010, 02:13 PM   #3
That'd be great - cheers!
Sam
Old 10-27-2010, 05:38 PM   #4
Jaxonalden's Avatar
Here you go Sparker, I have a couple more to go.
Old 10-27-2010, 05:50 PM   #5
Jaxonalden's Avatar
These are the rest.
Old 10-27-2010, 07:56 PM   #6
Actually looks kinda restrictive. The air flows inthrough the snorkle up to the top of the box, then down through the filter and out through the MAF. Makes two 90 degree turns at minimum and no clear path. Maybe an intake isin't such a bad idea. Anyone else disagree?
stuklr is offline   Reply With Quote
Old 10-28-2010, 03:47 AM   #7
Jaxonalden's Avatar
I made that argument a year ago...and it's four squared off 90 degree turns and then strained through the screen that sits just before the MAF sensor. I now have an EVO intake with an Outerwear pre-filter. It's a straight shot from the outside and no screen...the throttle response and intake sound is intoxicating.
Old 10-28-2010, 03:20 PM   #8
Brilliant - this was exactly what I was after!
Any tips on removal? Looks like it would just be those few visible bolts and obviously the intake pipe after the MAF?
I am quite positive my carbon airbox/intake pipe will be far superior to this stock item now
Sam
Old 10-28-2010, 04:18 PM   #9
Jaxonalden's Avatar
Quite honestly, if you want it out in one piece I think you have to drop the engine!! I removed mine...one piece at a time. I found my current Boxster air box on EBay for $25, I thought that if I ever sell my car I'd like to have all the stock parts to go with it. Good luck!
Old 10-28-2010, 04:37 PM   #10
JTP
I read a thread where a guy removed his airbox without destroying it. There was one mounting tab that he had to break off but it mostly came out in one piece. It might have been on Renntech. He gave a detailed thread with pics. I can't recall exactly what site it was.
JTP is offline   Reply With Quote
Old 10-28-2010, 04:39 PM   #11
hehe fair enough. Found a manual to the evo intake online which kinda gave me that impression. Removing the intake manifold seems slightly over the top..
Might have to source a spare one from the for sale section here to use as my build template - cant afford to have the car off the road for a few weeks in this lovely weather (its just coming into Summer in Australia )
Anyone have a spare they could sell me?
Sam
Old 10-28-2010, 05:05 PM   #12
JTP
Oh that thread I was talking about didn't remove the intake manifold. That's why he had to break that tab.
Old 10-28-2010, 05:28 PM   #13
If you happen to come across the thread - please let me know.
Cheers,
Sam
Old 06-28-2011, 07:52 PM   #14
Thanks for the reply, but I have safely removed my air box now and have completed my carbon intake project.
Very happy with the results too!
Cheers,
Sam
Old 06-29-2011, 04:07 AM   #15
Cheers,
Sam
Did you manage to get the airbox out intact ? Any tips ?
shlim8 is offline   Reply With Quote
Old 06-29-2011, 04:54 AM   #16
Crazy Austrian
harryrcb's Avatar
There are only 2 ways of getting the air box out intact (that I know of) 1. remove the intake or just loosen it on that side or 2. drop the engine an inch or two by loosening the front motor mount (4 bolts to the chassis) put a jack under the engine first (not a bottlenose or you will punch a hole in the case unless you put a block of wood in between) drop it down without disconnecting the coolant lines (same procedure for changing the front motor mount) and then you can remove the air box intact.
Crazy Austrian 007
http://www.ws-ab.com
harryrcb is offline   Reply With Quote
Old 06-29-2011, 03:50 PM   #17
Yep - took it out complete, undid the left side intake and also a bit of the power steering system.
Sounds daunting, but really wasnt that big of a deal.
Sam
