Old 06-29-2011, 05:54 AM   #16
harryrcb
Crazy Austrian
harryrcb's Avatar
Originally Posted by shlim8
Did you manage to get the airbox out intact ? Any tips ?
There are only 2 ways of getting the air box out intact (that I know of) 1. remove the intake or just loosen it on that side or 2. drop the engine an inch or two by loosening the front motor mount (4 bolts to the chassis) put a jack under the engine first (not a bottlenose or you will punch a hole in the case unless you put a block of wood in between) drop it down without disconnecting the coolant lines (same procedure for changing the front motor mount) and then you can remove the air box intact.
Crazy Austrian 007
http://www.ws-ab.com
harryrcb is offline   Reply With Quote
