		|  04-01-2016, 01:34 AM | #1 |
	| Registered User
				"Belle" The Boxster S Project
			Thought I'd post a few videos on what I've done to my 2001 986 Boxster S after a year of ownership and what mods I've got lined up for the future.
Video is here:
https://youtu.be/jKJTHuyQf4o
Porsche Boxster S 3.2 Tiptronic (986)
I wanted an everyday car I could track occasionally.
She’s called Belle
Stats.   252 Bhp, 305 Nm torque,0-60 takes 6.5 seconds, ,In the owners handbook its states the Boxster S Tiptronic version should weigh between  thirteen hundred and thirty five kilos (1335 kg)  and fourteen hundred and fifteen kilos  1415 kg , so we’ll take an average of thirteen hundred and seventy five 1375 kg for nowGives a  power to weight ratio of  183 bhp/ton
Had car for 1 year and driven 6,000 miles
Real world mpg
  17 mpg intown.
 30 mph on motorway
Using Shell vPower petrol (99 RON)
 Maintenance done
 My modsEngine Oil+Filter TwiceBrake Fluid TwiceTransmisson FluidCoffin Arms (bush in one place could see daylight though)Air And Cabin FiltersEngine Serpentine BeltBrake Pads – EBC BluestuffFuel FilterAircon Topped UpSpark Plugs
 Bulbs – Phillips X-treme VisionCustom Cup holder buildTyres – was pirelli p-zero russo now Michelin ps2CD player removed  and iPhone auxillary fitted with holderSpare tyre removed.  I carry tyre weld for punctures.GT3 brake ducts installed.Four wheel laser alignment
 Things to do
 IMS Bearing repairRefurbish complete braking system – the hoses, master cylinder, servo/booster and caliper rebuildsRear plastic window has a crackAlloy wheels have some paint bubblesSqueak from rear of car- could be engine mount, transmission mounts or suspension top mounts?Coffin arm bushes upgrade to polyurethane (Powerflex)Check and replace fluids – coolant, power steering and differential if needed
1997 to 2004 and it affects all Boxster, Caymans and 911’s from that time period.    The purpose of the intermediate shaft is to drive the camshafts indirectly off the crankshaft.  If the bearing in shaft fails this can affect the valve timing causing massive engine damage.  The fix itself is relatively straight forward you replace the bearing with a 3rd party version that doesn’t fail.
One thing I wanted to investigate is increasing the power of the engine.  What intrigues me is that 2001 Boxster produces 252 bhp but the 2005 model has the same 3.2 litre M96 engine but produces 280 bhp which is 28 more.  It would be interesting to find out what changes were made and seeing if I could get the same result.
		|  04-01-2016, 08:16 AM | #2 |
	| Registered User
			Looking good Neil!
		|  04-01-2016, 09:03 AM | #3 |
	| Registered User
			The passion you have towards your 986 is awesome. Beautiful color by the way, there's something about purple(and I'm hoping the color I see on your car is actually purple) on a boxster that I'm starting to be really fond of.
				__________________2000 Boxster S, SPEC stage 1 clutch, Fabspeed sport headers, Fabspeed secondary cat deletes, Billy&Boat muffler, EVOM air intake, Ben006's Custom Short Shifter, Pedro's TechnoBrace, Eibach rear sway bar, De-snorkeled, Fred's custom projector HL
		|  04-01-2016, 10:08 AM | #4 |
	| 2003 Base 5-speed
			Nice. Enjoyed it.
 I suspect the exterior is Midnight Blue Metallic (same as mine). Can look purple in certain light.
		|  04-01-2016, 12:33 PM | #5 |
	| Registered User
			We need more exterior pics with the sun hitting the car please
				__________________Woody
		|  04-02-2016, 07:07 AM | #6 |
	| Registered User
			Thanks for the kind words guys.   Will try to post some more pics soon.  Sadly it's not purple.  It's blue.  I should really look up the paint code but I suspect grc0456 is correct and it's midnight Metallic Blue.
 Any requests for mods I should do?
		|  04-02-2016, 10:28 AM | #7 |
	| Registered User
			Good stuff.  I don't know that I agree that your coffin arm bushing has any significant or objectionable wear.  Rubber looks good - no cracking or tearing.  The place where you refer as seeing daylight through being a problem in itself is not actually a problem in my opinion - this is just rubber casting flash that's been torn from the bushing motion, which is by design.  If it bothered you, you could use an x-acto knife and trim off this casting flash on a new bushing before you installed it if you wanted, and tuis very thin amount of rubber is not going to significantly affect the bushing's function.
 You are seeing some contact patterns that inside the rubber bushing is moving relative to the outer part under track loads, and replacing the bushing with stronger material or that's more rigid in shape (like without the holes you mentioned you can see daylight through, or with smaller holes) would keep it from moving around as much when using it.  There's a good chance this could allow the alignment to not move around as much dynamically, and basically give you more grip and better handling performance at the limit by maintaining better alignment under cornering and braking forces, although hardening the bushings could cause more noise/vibration/harshness for street driving application.
 Nice vid, just wanted to share that info / my opinion for what it's worth!
				__________________2001 Boxster
		|  04-04-2016, 10:26 AM | #8 |
	| Registered User
			Thanks for advice and kind words Jakeru.  In regards to the shot of the coffin arm that showed two holes in the bush (2:02 mark) do you think I replaced them too early?
		|  04-08-2016, 04:25 AM | #9 |
	| Registered User
			Next, I used bathroom scales in an attempt to weigh her.  Check out the results in this vid:https://youtu.be/071xPmVgE0E   |
		|  04-13-2016, 06:11 AM | #10 |
	| Registered User
			Next up swapped out the brake master cylinder and booster
Video is here:  https://youtu.be/LsVANgHiR84
		|  04-19-2016, 05:55 AM | #11 |
	| Registered User
			New steel braided brake lines go on.
Video of how it did it below:
https://youtu.be/Czvr1_lNZew   |
		|  04-19-2016, 06:39 AM | #12 |
	| 2003 S, Arctic Silver, M6
			Neil, thanks for all these 'how-to' videos. Great information and really good productions.
		|  04-19-2016, 08:44 AM | #13 |
	| Registered User
					Originally Posted by paulofto  Neil, thanks for all these 'how-to' videos. Great information and really good productions. |
Ill second that
				__________________99 Box 3.4, PSS9's
		|  04-19-2016, 09:40 PM | #14 |
	| Registered User
					Originally Posted by neil_b  Thanks for advice and kind words Jakeru.  In regards to the shot of the coffin arm that showed two holes in the bush (2:02 mark) do you think I replaced them too early? |
Yes, those gaps in the bush at 2:02 are definitely supposed to be there.
Well done on the vids.
				__________________2001 Boxster S, TipTronic in Seal Grey aka "The Imp"
 2001 TE50, ESS in (now) Grigio Titanio Matallizzato aka "The Golden child"
		|  05-03-2016, 08:36 AM | #15 |
	| Registered User
			Thanks guys for the kind words.
		|  05-04-2016, 02:42 AM | #17 |
	| Registered User
			How are you finding the braided hoses? I love the feel of the pedal as standard, the progressiveness you get out of it is quite informative to what the brakes are doing. I'd love for the brakes to be better (as would anyone) but I wouldn't want to get rid of the feel.
 How are they?
				__________________Porsche Boxster S Type 986
 Bi-xenon Headlight Upgrade   |   987 S 18" Anthracite Alloys   |   Android Head Unit   |   5000k 55w HID's   |   5000k Cree DRL's   |   5000k Cree number plate lights   |   Cree LED Indicators   |   One-touch roof operation   |   Bypass exhaust pipes   |   Parking sensors   | Ambient footwell lighting
		|  05-04-2016, 08:31 AM | #18 |
	| Registered User
			what an informative post!  will be following this thread for some good reference! Thank you.
		|  05-08-2016, 11:16 AM | #19 |
	| Registered User
					Originally Posted by geraintthomas  How are you finding the braided hoses? I love the feel of the pedal as standard, the progressiveness you get out of it is quite informative to what the brakes are doing. I'd love for the brakes to be better (as would anyone) but I wouldn't want to get rid of the feel.
 How are they?
I haven't noticed any difference in pedal feel with the braided hoses with day to day driving.  Have a track day in two weeks so will report back after.
		|  05-08-2016, 11:17 AM | #20 |
	| Registered User
	|  Posting Rules |
		You may not post new threads You may not post replies You may not post attachments You may not edit your posts
 HTML code is Off
 |  |  |  All times are GMT -8. The time now is 06:30 AM.
