Old 11-15-2015, 08:48 PM   #1
I had one last thing to save off this before I put it over in the "buzzard yard". I thought it had the S M030 suspension. I don't have the hood anymore to confirm what I think I remember. It measures 24.0mm but so does every other S sway bar I measure. Even the sway bar on my S measures 24mm. My car didn't come with the M030 package from the factory. Does anyone know how to tell the difference between a S sway bar and a S M030 sway bar besides measuring the diameter? The one I think is a S M030 has no part numbers and only has a green paint dot on it.
Got my radiators cleaned out and back on. Decided to throw a GT3 bumper and skirt on it to see how much prep work I would have to do to them. Surprisingly they fit pretty good and won't need much work before painting. They're duraflex brand or something like that. They're fiberglass ,but flex better than other fiberglass products I've had before. I'll use them if I don't come across a factory polyurethane kit before I paint.
Woody
Old 11-24-2015, 04:02 PM   #2
Technically you only need to switch out the transponder inside the key, immobilizer under the seat and the DME in the trunk. For test purposes, I switch out the ignition cylinder because it only takes a few seconds. I've never had a chance to see if a tip DME will run in a manual car or vice versa. A 3.2 manual DME/im/key will work in a 2.7 manual for 2000-02. A 3.4 DME/im/key in a 3.2 car will only run for a few seconds and then die. I believe 2003-07 use the same DME, but they switched immobilizers in 05. I've only learned by taking these things apart and reading up on threads. I tell people all the time, "I'm an expert at taking them apart but not working on them". That's one of the reasons I started this thread. There will be points on this build where I'm over my head and will need some help from you guys. Mostly when it comes to the stereo and what engine I end up getting for it.
I think I forgot to say thank you for the reply - so thanks!
TrumpyAl is offline   Reply With Quote
Old 11-16-2015, 05:39 AM   #3
RedTele58's Avatar
That's gonna be a nice looking ride with all the added goodies!
Old 11-16-2015, 06:37 AM   #4
Concerning the sway bar -
I bought a 2002 Boxster S M030 front sway, which also has a green dot. I was hoping the mounting hardware would be different and lead to some clues, but it appears to be the same for non-M030.
I did find this on renntech, courtesy of Topless a few years ago:
(996-343-701-23 vs -21)
21= Base M030 (*and S non-M030 per Pelican parts*) 23.6mm 3.5mm
23= Box S M030 24.0mm 3.8mm
So it should be very slightly thicker, or maybe you'll see a slight weight difference if you have a very accurate scale...
CraigM is offline   Reply With Quote
Old 11-16-2015, 12:33 PM   #5
mikesz's Avatar
Great project! I love Arena Red!
99 Porsche Boxster
Old 11-16-2015, 01:27 PM   #6
98 Arctic silver 986
tommy583's Avatar
Woody, your car looks great even with no headlights and black bumper. That thing is gonna look bad ass when you get done
Old 11-17-2015, 11:46 AM   #7
DAMN! The car is looking amazing with the bumper/skirts and those rims.
martsink is offline   Reply With Quote
Old 11-18-2015, 07:41 PM   #8
Thanks guys
I plan on starting a thread one of these days about springs and sway bars. What I'm finding on these cars isn't coordinating with what books/internet is telling me should be on these cars.
Started on the interior today and first up was the easy stuff. I swapped the stock speakers with the Bose speakers. I really liked the Bose system and it's more than enough for me. Those days of 15 inch subs are long gone along with some of my hearing. Here's a pic of the stock HAES speakers next to the Bose. Some HAES speakers come with tweeters and some don't, but you cant tell the difference between any of them from the top side.
The door speakers interchange with no problems, but the sound insulation is different.
While I was there I also decided to switch out the window for some darker tint. The sun down here is brutal on interior.
I've been saving the 996 leather door panels for awhile now and I really prefer them over the 986 door panels. Both 996 door panels need to be reupholstered, so i'm going to keep the 986 panels on it for now.
This shifter was a great surprise to find on a car. There's no markings on it to track down what manufacture made it.
Woody
Old 11-20-2015, 10:03 AM   #9
mikesz's Avatar
Adustable track arms Pros/Cons? experiences?
Any thoughts on those adjustable arms? I am planning on rebuilding my suspension one of these days and have seen them. What are the Pros/Cons? I have no intention of racing or tracking the car. Also, I have my alignements done by a shop.
99 Porsche Boxster
Old 11-20-2015, 12:09 PM   #10
It's funny you ask. A friend called me up after reading this thread warning me about those arms. He said his broke at the same place and suggested I drill and weld on the backside too. I can't remember if he said he switched them out or still uses them. They're on his SCCA Boxster S and get a workout being on his car. From what I could find out searching the interenet. They're made in china and sold by a few companies. I'm confident in my welding and the welds on the other end, but I wouldn't buy them new. I was told you need them if you lower your car and run coilovers.
Woody
Old 11-20-2015, 02:18 PM   #11
Adding to what Woody, commented above as the previous owner of his adjustable control arms, they're heavy compared to factory parts or performance versions from more reputable shops... but the price of the performance shops on these arms is pricey!
Old 11-20-2015, 06:30 PM   #12
Dang - who made these control arms? I'll be buying some (hopefully) soon, and would rather pony up to avoid a potential wreck...
Old 11-21-2015, 03:37 AM   #13
Here's a link to GOOD QUALITY suspension parts...
986/987/981 Control Arms
The part that broke on Woody's bench was the thrust arm. Tarrett sells them for $350 each.
Old 11-21-2015, 04:02 AM   #14
mikesz's Avatar
thanks for the info but pricey. I think I will stick to stock parts. I plan on putting bilstein HD and lowering springs on the car.
99 Porsche Boxster
Old 11-23-2015, 04:47 PM   #15
Installed some 03-04 side vents on today. I wasn't sure how I would like the color difference before I did it, but I'm really digging the black vents now. I need to restore the wheels at some point and was thinking about powder coating them gloss black. I think going with gloss black wheels and vents will tie into the dark tinted windows and light tinted tail/side lights. I plan on going with projector headlights at some point. I can't decide if I should go body color, gloss black, or flat black for the headlights. Particlewave had a thread where he painted the insides of his. I need to go search up that thread again.
Vents can be finicky sometimes. Sometimes they slide right out and other times they can be a major PIA. The ones on my 00 were the hardest ones to ever get out. I destroyed the black plastic slats on the left side. I tried for 20 minutes to get it out without breaking it, but I got impatient. When you get impatient you break one of two things. Either the attaching fingers on the black plastic or the corner retainer on the painted part. Look at the bottom right corner of each vent. That holds the vent onto the body on the leading edge of the vent
Woody
Old 11-24-2015, 09:05 AM   #16
mikesz's Avatar
so what is the difference between the 1st gen and 03-04 side vents? they look like they sit more flush with the body?
99 Porsche Boxster
Old 11-24-2015, 06:30 PM   #17
The slats are molded into the vent on the 03-04 and stick about 3-4 inches farther out. The 97-02 slats are part of the black plastic part that holds the vent to the body.
Woody
Old 11-25-2015, 04:56 AM   #18
Project Addicted
jcslocum's Avatar
That nose looks quite a bit like the one we picked up. Haven't tried to paint it yet, Too damn cold already here in NY, 20 this morning....
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
Old 11-28-2015, 04:59 PM   #19
I've been watching your build and our cars will look very similar. I'm almost thinking about copying your spoiler idea. I want to do something too but haven't figured out what yet. I really wish someone would build a ducktail for the 986 boxster. I think that's the look I'm really after.
Relocated the battery today. I've seen a lot of 996 and 986 guys move their battery for better weight distribution. Most I've seen move it to the passenger floor because that's the best place if you're trying to shift weight to the best spot. That won't work for cars that still carry a passenger. The other option is to bring it down into the frunk. I still need to carry a spare, so I put it in the best location that the tray would sit flat. I used a preexisting ground location. It's a little bit smaller and I have some ideas to help create more surface area for the connection if problems arise.
Woody
Old 12-06-2015, 06:21 AM   #20
mikesz's Avatar
I think we should all move down to Texas, and just camp at Woody's! Bring tools!
99 Porsche Boxster
HTML code is Off
