Old 07-16-2015, 09:16 AM   #301
That's awesome to hear! Did you get the AC going too? Steve 2 day priority shipped over the flywheel bolts were missing from the kit :ah: Spec sent me the wrong clutch disc (ended up with a regular clutch, they had my flywheel 3 months and nothing in regards to the twin disc). It wouldn't be a project if everything didnt go wrong lol.
2003 Boxster S
997 Turbo Front End Conversion
Widebody Rear Flares Aerokit II Side Skirts
18x9 Front 18x11 Rear Wheels
Twin-Turbo LSx Boxster :troll:
Lcrivers816 is offline   Reply With Quote
Old 07-16-2015, 01:11 PM   #302
Registered Abuser
Flywheel bolts were supposed to come with the kit?!
...add that to my list as well.
Bayley is offline   Reply With Quote
Old 07-16-2015, 03:08 PM   #303
Sucks to hear about your clutch, hopefully you get it soon, we need updates man!!
I actually started to test fit the AC lines the other day and did some figuring... I figured that the way I have things set up the factory lines bolt right up to the compressor with just enough clearance to get by, just need to have the fittings removed from the other end, cut down the lines and have them re-crimped, bada bing. I also need to sort out the belt but that shouldn't be that big of a deal now that the alternator is sorted, although I think i'll need a bit shorter belt.
I'm gonna take the car to work tomorrow and think i'll mess with that a bit, it would be nice to have A/C!! I also need to see if I can get the rear firewall made and perhaps a cold air box for the air filter as well, hopefully that guy will be around tomorrow.
Regarding flywheel bolts, mine came with the kit but I bought the upgraded clutch kit for $1000~ so it was all nicely packaged together if I recall. All of the bolts for the clutch/flywheel were in a 3 section plastic bag which was heat sealed. If you didn't buy the upgraded clutch not sure if you would get them or not.
Good luck!
J
BoxsterLS376 is offline   Reply With Quote
Old 07-19-2015, 12:17 AM   #304
Yup, the flywheel bolts were supposed to be there. I didn't purchase the clutch
martsink is offline   Reply With Quote
Old 08-03-2015, 07:29 AM   #305
Well i finally broke it~
So just a quick little update...
Well I figured it would happen eventually but was hoping it would last more then 600~ miles
Hopefully i'll be able to come up with some better videos here in a bit as I got a little gopro type camera, which I was testing on the way home from work Friday and came around one of my favorite corners in 2nd gear, gave it the beans and BAM KLING KLUNK RATTLE Turns out I found the limits on the axle as it came apart on me on the ride home, WAH WAH WAH.
Doesn't look like anything broke in particular but rather came apart because of too much angle to the dangle. That and I was stressing it out about as much as possible making a right hand 120* uphill turn. Was it my fault, yeah sure, but what is the point of having a car like this and not driving it like an ass a bit?!?!
So I ghetto repaired one of my original axles and put it in for temporary purposes... now I really need to look into upgraded axles, only problem is that I don't think anyone has made any, including Renegade. They were talking about it a few months back but haven't heard anything going into production.
I found a few companies out there who will make custom axles etc. so may just have to have a set made up special for it. If I go this route I may have them made just a bit longer to help compensate for the transmission being back a bit further.
So to recap, if anyone has suggestions for upgraded axles, please let me know!
Also can anyone suggest a decent easy to use program for editing .MOV video files? I'll post the video of the axle blowout as soon as I can cut the video down to size as I'm sure no one really want to watch my whole ride home
J
Old 08-03-2015, 09:34 AM   #306
Registered Abuser
Any idea what actually failed?
I'm wondering if the CV joint is popping out of the cup after having the transmission moved backwards that extra inch. I've recently learned the importance of having proper CV to cup engagement after having my race car (don't get all excited, it's a 1992 Plymouth Sundance...) pop the axle on lap 1 of a 24 hour endurance race.
We swapped to a more modern engine and redesigned all the motor mounts. Unfortunately, the geometry wasn't quite spot-on and we were blowing passenger axles within a lap or two. We eventually made a 1/2" spacer between the outer CV axle and the hub that pushed the axle further back into the trans. Once the spacer was added, the axles stopped failing.
Just throwing this out there because I have my concerns about moving the transmission back without lengthening the CV axles.
Old 08-03-2015, 11:15 AM   #307
Thanks Bayley,
Yes that is actually what we are going to try first because I do suspect that moving the transmission back just a little is the cause. I'm gonna get the bad axle cleaned up and see what went bad other then just pulling apart. I know there are a few raised areas on the outer portion that I saw but could be more - find out soon enough!
J
Old 08-13-2015, 09:20 PM   #308
Originally Posted by BoxsterLS376 View Post
Thanks Bayley,
J
Hey, did you find anything suspicious when you pulled apart the axle? I'm trying to get my car on the road next week and I really hope this doesn't happen to me.
Old 08-15-2015, 02:16 PM   #309
I found them to be suspiciously short No but really it appears to have just pulled apart for the most part. The outer CV joint appeared to be riding on the very outside of the joint from the wear I can see and the combination of a heavy load with an uphill right hand turn pushed it to the limit. You can see 2 spots where the metal gave way when it finally let go and pulled apart on the outer portion of the CV joint. The cage itself it still fully intact although it does have a crack that I can see but I think that was not the cause of it.
I think I have a solution though which for testing purposes will be fine and could be a permanent solution. Hopefully a spacer on the transmission side will be all that it needs so I'm going to get my CNC guy to make some up then will need to get some longer bolts. I'll start with 1/4" and will get a 1/2" one made as well.
I've got everything I need to rebuild my factory axles now although I'm in no hurry until I can get this damn check engine light sorted out, technically the tag is expired now so I need to find some one who can turn the idle down on it but so far no luck
Old 08-19-2015, 09:55 AM   #310
I might be interested in those spacers. Let us know how it goes.
Old 08-19-2015, 11:13 AM   #311
The Radium King's Avatar
tarett sells rear axle spacers. not sure what tranny you are running (thread way too long) but 's' axles are longer but would require you swap the hubs as well.
Old 08-20-2015, 06:13 AM   #312
Yup the kit they sell is exactly what I was thinking...
Axle Spacer Kit, Rear, 15mm, 986 /987/996/997
It would be easier to buy one from them but @ $185 I think I'd rather wait and see if my guys can cut a few out. I'll may call them up and see if they will hook me up... I'm not very patient
Old 08-24-2015, 07:00 AM   #313
Registered Abuser
...I like this option. Thanks guys!
Old 08-24-2015, 12:12 PM   #314
Me too!! Give Ira @ Tarrett a shout and he can set you up - iraramin@tarett.com. I was going to have my CNC fab guy up the road make a set but by the time they do all the CNC drawings raw materials etc. it would cost me that much, take longer to get done, and I'd still have to find the bolts!
Thanks to The Radium King for pointing these out to me!!
I took the time last week to rebuild one of my factory axles and installed it on the car Friday. I was checking the amount of room I had between the axle and transmission when the outer CV is compressed and there is over an inch of travel so these 15mm spacers are going to fill the gap nicely!!
Only thing left to make me feel 100% about it would be an LSD... which technically I have I just need to pay my boss for it! Of course if I pull the transmission out to do that then I'll go ahead and get all of the gears cryoed and REMed to make it as strong as possible. I think I took some pictures of a few 914 V8 gear boxes we just put together, it pretty sweet. Takes all of the surface imperfections off the gears, almost looks like they have been polished/chromed. I don't really want to have the car down that long right now as we are coming up on perfect driving weather here in Georgia soon!
I don't suppose anyone has a spare 6-speed S gearbox they want to donate or sell REALLY cheap eh?? Can find them on Ebay for about $1200~ but I'm so tapped out on this project it is not even funny so it'll likely have to wait!
J
Old 08-27-2015, 10:19 AM   #315
:troll:
Soooo... this morning started out well, it's been pretty nice so I decided to go ahead and drive the Boxster in today... took a back road in and saw about 5 deer grazing, it was great!
Ever since I put my factory axle back on I've been getting a little vibration under acceleration which can't be good. This morning was no different but I persevered anyway. So I was almost to work when I pulled out onto highway 41 second gear and leaned into it around 3K or so once I was going pretty much perfectly straight and moments later BAM!! ********************.
This time it was the drivers side which is still the brand new aftermarket axle... starting to think these aftermarket axles just aren't up to this task. Luckily I was almost done rebuilding my other factory axle so I got a ride to the shop and finished putting it back together, went back and swapped it out in the parking lot I broke down in. What a PITA. It is really not that bad of a job but I'm getting sick and tired of doing it!!!
So needless to say I got it going again and limped it back to the shop where it will stay parked until my Tarrett Engineering axle spacers show up sometime next week. Hopefully that alleviates the problem.
I tell you what shocks the piss outta me is that in my last conversation with Steve @ Renegade when I told him what happened with my first axle he reassured me that they haven't broken any axles except on a track car which had been running for 6+ months. They just run stock axles, no mention of custom anything, spacers, LSD, nothing. I just don't buy it. Does my engine/transmission somehow sit further back then theirs do? I dunno but once I put in these spacers I'm gonna run the piss out of it here on the street in front of my shop so I don't get stuck in a random parking lot again. Hopefully it solves the problem.
Old 08-29-2015, 03:39 PM   #316
bc993's Avatar
The axle geometry was always my biggest concern on this transformation. However all the sand rails I've seen built have more abrupt angles and seem to have no issues but the sand gives a bit unlike pavement and wanting traction. I'm also not surprised that Renegade was not forthcoming on anyone having axle issues but i bet they have them. Hope the Tarret spacers fix the issue.
bc993 is offline   Reply With Quote
Old 08-31-2015, 04:03 PM   #317
Tarett Engineering Axle spacers save the day!!
You sir seem to be correct! I don't believe it to be the angle of the dangle but rather the distance between A and B!
Greetings all!
If you have been following along the you know I've had a few axle issues lately The outer CV joints were getting stressed to much and pulling apart due to the transmission being set back further in the chassis.
I wanted to get longer axles when we came up with the idea to just add spacers! Waaay cheaper and better option, at least for testing purposes, and if they work out fantastic! So I put my idea out here, got some great feedback and found out that the spacers I was going to have custom made already existed!! w00T w00T!!
Thanks again to "The Radium King" for pointing out that Tarett Engineering who are well know for competition level suspension systems already had spacer kits available!!! OUTSTANDING!@!
The spacers are 15mm and their kit comes with the appropriate sized bolts in 12.9 grade!!! Took less then an hour to install and fit perfectly...
Better yet I can already report that this has made a VAST improvement to the overall feel of the car. After installing my recently rebuild factory axle I had been getting some vibration under acceleration which seems to be gone although some longer term testing will need to be done to be sure.
Also gave it the good 1-2 in front of the shop a few times and haven't broken anything yet! I've got a video of that too which won't be publicly posted to youtube just because
Here's a look at the Tarett Engineering Axle kit which has saved the day and hopefully saved me from having to do any more parking lot axle swaps!!!
Video should be done uploading in just a few minutes~
http://youtu.be/2oEJ-wPirb4
Thanks!
J
Old 09-06-2015, 01:39 AM   #318
So quick update, no more check engine light! w00T w00T!!
The car has now officially passed Georgia emissions, easy peasy lemon squeezy.
Turns out I had a vacuum line in the wrong place basically. The fuel tank vent/purge line was the problem, for convenience I plumbed it directly to the intake manifold which on the Porsche motor is about how it is except that it has a purge valve on it so as not to create a vacuum leak.
Seems that the Chevy motor didn't like the extra fuel vapor/vacuum it was getting and was causing the idle to be "higher then expected", even though there is no noticeable difference in the idle. Once I re-routed the line and fired it back up, light was gone, YAY.
Old 09-06-2015, 07:49 AM   #319
Cars running like stock Boxster awesome.
Congrats on passing the test!
shockandawe is offline   Reply With Quote
Old 09-06-2015, 08:33 AM   #320
Pdwight's Avatar
Yes, big time congrats
I had a few head to head issues with those guys back in the middle 90's and our fleet cars back then........Oh the good ole days when you could actually make a decent living .....LOL
HTML code is Off
