06-21-2015, 09:51 AM
#81
WALDMEISTER
Thanks!
Alu meshes test: 1/3 middle segment version
car might run marginally hotter with full meshes, but I would say neglectable.
With the 1/3 solution, no heat problems at all...but +33% less bugs and debris
06-22-2015, 09:47 AM
#82
WALDMEISTER
PORSCHE 911R...NICE!!
lol...my red stripe design from 2014!
06-29-2015, 11:51 PM
#83
Originally Posted by BRAN
The Fuchs alloys remind me of my 356 which sold earlier this year [they were not standard on that either as the original had steel wheels]
I have Carrera alloys on my Seal Grey S which are very open.
Shows off the red Brembo's very well.
John
07-02-2015, 07:52 AM
#84
WALDMEISTER
WHAT A BEAUTY!
Priceless...
congrats, John
07-11-2015, 09:25 AM
#85
I think I have a Grey problem.
07-12-2015, 07:21 PM
#86
Rookie
Crappy cell phone pic but sporting the newly restored smoked headlights and new smoked side markers together. Next shot will be when I add the custom windscreen...
02 Seal Grey 5 Speed
08-17-2015, 02:21 AM
#87
WALDMEISTER
08-17-2015, 05:00 PM
#88
2004 S with 78k
Had her for two weeks and just got a clean bill of health from local Porsche tech
08-18-2015, 01:28 AM
#89
Very nice! Enjoy!
2001 Boxster S 6-speed, 2013 Boxster S PDK
08-18-2015, 04:06 AM
#90
Welcome to forum, Porsche Boxster and Seal Grey
I do love the color
Mine just turn 80k
Seal Grey
08-22-2015, 03:25 PM
#91
Rookie
I think lowering my Seal Grey deserves a before and after...
Before.....
After.....
08-23-2015, 12:14 AM
#92
WALDMEISTER
Looks fantastic!
Tell us more about your new wheels and suspension (and your fleece seat covers  )
08-23-2015, 06:10 AM
#93
Rookie
Looks fantastic!
Tires and wheels were a screamin deal on craigslist. 19" SSR GT3 rims wrapped in Michelin Super Sports with about 70% tread remaining, came off a 911 and the offset required 10mm spacers in the rear to fit. I also got new chrome lug bolts as the stock bolts werent long enough after I added the spacers. They did not come with the center caps and I seriously considered the brushed aluminum "SSR" center caps but at, IIRC, $200+ for the set it just wasnt worth it. In the end I got Chinese knock-off Porsche center caps off fleabay in dark grey with both the grey emblem and a set of dark grey with the colored emblem. They were $15 a set and have held up very well and are a perfect match to the rim color. As for performance it was a significant reduction in ride quality. Steering is much more responsive over the 17" turbo twists and Michelin AS3 tires they replaced, the car also seemed a little lighter and more nimble. $650 for the tires/rims, $75 for the spacers and $60 for the lug bolts.
Suspension was also a screamin deal on craigslist. Theyre Bilstein sport struts and Eibach lowering springs that came off a Boxster with 60k miles on it. $450 for the set and another $450 for a pro install and alignment. It only lowered the car about 1" but changed the character of the car considerably. Both from the outside and inside its a more drastic change than I imagined it would be. Inner fender lips were rolled to avoid rubbing and the required "outer limit" 2 degree negative camber will reduce the life of my rear tires by a further 50%, and thats beyond the Boxsters' already big appetite for rear tires. The suspension expert stated running asymmetric tires will help, and that tire manufactures have come a long ways in improving asymmetric technology, but I can still expect a significant loss of rear tire life as a result of a lowered car and the camber required. In my opinion its well worth it. Yes the reduced tire life sucks but from both a cosmetic and performance standpoint I still think its the way Boxsters should ship from the factory. It increases the impression that youre driving a sports car. The improvement over a stock base Boxster is, obviously, reduced body roll but also a smoother ride. Yes rough roads are a little rougher, and overall the car is a stiffer ride, but its also a more fluid ride over the stock suspension and a more solid feel behind the steering wheel.
The seat covers were my very first improvement when I purchased the car. I almost always drive top-down and the covers were added for no other reason but to prevent sweating in the seats, and they work great. I think it was a step down cosmetically over the black leather seats but getting out the car without a sweaty ass is priceless to me. Its been a while but if memory serves I purchased them on line from autoaccessories.com for $200. Expensive but I wanted real sheep skin and as close to the car color as possible.
08-26-2015, 11:11 AM
#94
WALDMEISTER
Porsche crest in arm rest...as if it was meant to be there in the first place
What you need:
Porsche crest
Betalink K1 glue (black) --> rock solid weather proof automotive glue will keep the crest in place for ever
cutter knife
dremel (to get rid of glue residue, to grind and flatten underground a bit)
ball pen (to outline crest shape before cutting)
edding Mattlack-Marker edding 4000 (outline crest in matt black)
11-15-2015, 06:51 AM
#95
WALDMEISTER
zunsport mesh grilles (kept the chrome trim behind them)...
Grilles are pretty shiny though hard to see in the photos here, IMO a perfect old school "chrome" look
11-15-2015, 04:09 PM
#96
Looks good Bran.
I always like seeing what you are doing to your car.
11-17-2015, 12:34 PM
#97
WALDMEISTER
Originally Posted by RedTele58
Looks good Bran.
Many Thanks
2 more mods in the works...and many more to come
11-30-2015, 10:19 AM
#98
WALDMEISTER
What changed?
Hint: Barely noticeable, a really time consuming mod...didn't use a dremel, but a file
12-01-2015, 09:08 AM
#99
WALDMEISTER
...not easy, I know
:dance:
12-05-2015, 09:37 AM
#100
WALDMEISTER
Happy belated 15th B-day (late November actually)
...50.000km...you made it finally, you're a honey!!
| Thread Tools |
| Display Modes |
Linear Mode
HTML code is Off
